  • Replies 196
Posted Images
geez I can't believe all these softc0cks pulling out .... oh hang on, I can believe it:
haha you beat me to it Steve - as per normal SAU events, just over half will actually turn up. The rest will come up with pathetic excuses like 'I completely forgot about it and went out and got smashed', 'I slept in', 'I couldn't get away from work' etc etc :)
:):D:huh:
See the rest of you guys who bother turning up at Scoozi for a latte at 8pm.
lol oh wise one andrew :)
shane finish up when your tired
Joel you able to at least make coffee :D
blue is a pretty colour look @ the highlites in my signature :)
anyways im off getting dressed and picking up Mark
hahaha yeah the inaugural SAU:SA lan was awesome .... sorry I couldn't hang around longer, but have to do the right thing by the wife and a teething 7 month old :)
Great to catch up with some old faces, and meet some new ones!
We will have to make this a regular thing! Thanks heaps ArenaGTR for putting it on, and Steve for his organisational skills.
not too sure who the champ was but it wasnt me hahaha
thanks all was good fun and something different! once again cheers for the lift steve pleasure to meet ya
Arena, thanks for havin us champ!
:P
was a good night. good catchin up with the usual suspects and meetin a few new ones.
hows that investigation coming pete? :P
surprised pics of cs:sauce havent come up yet. there were quite a few people with their phones/cameras out.
and mark, you are freakishly good at starcraft. i mean, goddamn.
lookin forward to doing it all again. :(
no worries all, was good to have you all there, sorry I couldn't spend much time playing games with you guys cuz we were literally packed out, so I took my shisha out and smoked it instead :(, and kietz, I think u got the wrong way around, "if you can't beat kietz, u can't beat me" =.='|||
definately gonna organise this event on a regular basis (/me looks @ Steve - thanks laahhh)
Thank you for all that came to the event, was great fun uleh, I pwned hard in CS: Source muahahaha (old & rusty), but anyhow, thanks again guys.
P.S. Was that Sled @ Arena? (ELLO THERE) he's so big and tall, was afraid to go up to him and say hi :P
Edited by ArenaGTR
i heard about said sauce incident. cmon guys where are the pics?
cheers to steve and Arena man, was good fun even though i got majorly whipped. Never played at 1 those things so it was something out of the norm.
i cant believe jenkies whipped us all at the same time at starcraft wtf. i think next time ill make more towers, atleast i made you take that extra 3min to beat me the second time.
CS kept getting me confused who was on who's team, all the men look the same when you shooting them from far away.
popping people in the head is always fun :( but next time wouldnt mind a car race game chucked in there someone for good measure if anyone else is keen
still getting over the large supply of tissues there :P
all in all good ta see ya guys and meet a few new people.
o and yes pete is scary, he rides 1 of those bikie harley looking bikes.
Edited by gzilla
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
