hey,
atm i currently have a power fc for my rb20det...
now i know these are great units etc.
i have tossed up selling this and getting a remap of my std ecu..
will this have the same effect? is having the pfc better?
will i loose anything getting a remap?
i dont know if I am gonna get the most out of my $1000+ pfc as i only street the car!
standard rb20
Apexi AX53B70 P-25 (380hp)
gtr injectors and pump
z32 afm
ap engineering power fc
600*300*100
3" dump, no cat and 90mm cat back
E boost controller
standard bov
this is wat i have to tune!!
i found my car feels better with the std ECU! am i just strange or ???
cheers
adrian
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/
the powerfc is only as good as the tuner or the owner who tunes it
if you just plug it in its no different to the standard ECU
its just maps and numbers, theres no "magic add power" function in the powerfc
that being said, if you have some time to read and a good mind set you can do a lot of the tuning
and adjustments yourself, saving time, $ and getting some gains from your investment
youll also learn quite a bit which is good - and you can brag to your mates that you did some self tuning
the powerfc faq in my sig covers everything you need to know with the powerfc
it covers common topics such as fuel economy tuning
adding more ignition timing for response and power
common upgrades and changes such as airflow meters, injectors etc
also covers debugging knocking and detonation and how to check for them
the stock ecu is fine and once remapped will give you more power and resposne etc
but all of the tune and information is locked away and you have no access to it
so you dont know if things are good or bad, as you cant tell
you also cant make adjustments (even minor) if you want to make changes
or use different fuel (say 100ron) or change airflow meter etc
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3828849
as a quick test has the PFC been tuned properly? if it hasn't then no wonder you believe the stock ecu feels better
well if it hasn't been tuned properly throw in some more ignition timing
get the car warm
use the temp IGN adjust on the hand controller
add in +5 IGN timing and drive around
watch knocking on the hand controller and load the car up
keep it under 3 grand on full load and see how it goes (dont go past 3 grand, youll likely kill the engine, get a real tuner to do this on a dyno)
if you get low levels of detonation (under say 20 ish)
then this level is fine and you can deal with more timing
basically just keep doing this until you get consistent levels of knocking around 20ish under load
i did this on my std turbo GTST 33 and got massive response gains
i was able to dial in about +12deg ign timing over the std maps
this gives the car a massive boost in throttle response and makes the car nice and crisp
as you can see with the stock ECU you have no hope of doing this
also if you try out 100ron fuel such as Vpower Racing you can do the same procedure
and add in even more timing ,again giving more power, response and throttle crispness
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3828870
hey,
standard rb20
z32 afm
600*300*100
E boost controller
standard bov
cheers
adrian
Well the gear you have fitted will make both Re-map or PFC nice and easy to tune - congrats on not installing 1000cc injectors for your 380hp turbo as I often have seen. As Paul has said either or can be tuned - just make sure you get a good tuner. The Knock light feature on the PFC is nice even if it doesn't retard the timing as the factory ECU "WILL/SHOULD" - but it often doesn't.
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3828873
get the car warm
What happens if the wiring to the knock sensor is faulty??? No fault codes, No knock numbers no flashy eninge light.
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3828887
well that would also yield a knock display of 0
and it would never change or increase
this would be the same with a remap, the stock ecu would never see a knocking signal
so it would never drop to the low octane map
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3828954
On the std ECU it would automatically drop to a default timing number and display an engine light if the sensor was open or short circuit.
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3828967
with that kinda setup, if u have the cash for a PFC and tune... the way i figure it is re-map's are better for mininmal mod's like what im doing for my car, but then again it depends on the re-mapper really.. If they have exp with high HP cars and are good then go for it, but to be honest if i had the mods u had id spend the extra cash and go a PFC and tune
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3829356
A remap will be fine for his setup...which is similar to mine...but since he has a power FC then he should just stick with it...makes no sense to change it....
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3830093
hey,
standard rb20
z32 afm
600*300*100
E boost controller
standard bov
cheers
adrian
considering i had exactly the same setup as this, except a gtr bov and a bleed tap (which is better than a e-boost anyways haha) and had both a remap and power fc in my car....
i would go the remap and with the money you save get yourself a set a spiltfire coils as you will need them
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3830231
Hold onto the Power FC and make use of it
To tune the Power FC it will be pretty much the same as what you would pay for the REMAP
The way I see it, the Power FC can only go up in value from here on so you won't lose out when you sell it later down the track
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3831361
but on the other hand if u sell the power fc and use the cash to buy some splitfires, you wont get super agro when trying to tune power fc only to have your spark blown out because of shitty stock coil packs
plus u will have some cash left over to replace the gtr fuel pump with a bosch one when it shits itself
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3832717
I don't believe he will need splitfires, the most power he would be looking at would be what:? maybe 240rwkw?
Standard coils will hold that provided they are still in good condition
cerbera: Did you once own a black HCR32 with an Apexi AX53B70 turbo?
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3832746
they will be fine for that power, i have standard coils running 430rwkw and they are fine...
but they are very old and starting to degrade, its not the performance of the coils, its the wear and tear
yes i did own a black 32 back in the day, why is this?!?
https://www.sau.com.au/forums/topic/216845-to-pfc-or-remap/#findComment-3832780
