Item:R34 GT-R 6 Speed Gearbox
Age:2000 model V Spec
Condition:Very Good 18k klms
Price:$3300
To Fit:Any GTR, GTS-t, GT-T
Contact:0405901010
Comments:Selling due to upgrade to Dog box, dont want to break original getrag box. Never raced, used as a weekend car until end of engine build which will be taking over by dog box.
Willing to freight anywhere in Oz for $100 on pallet secure freight insured.
Edited by F u r i o u s
with the 6speed and knowing that the attessa works faster on the R34 gtrs than R32 n R33...can the attessa control module be used from R34 to R32 GTR's and get the same response? Also the transfer case having a lil pre load to it from the newer models.
can this be done?
sorry 2 H/J good luck with sale
can this be done?
I dont think thats possible, you'd have to change the pumps and all the electrical gear to get your 32 going like a 34. (tho i dont know what is actually different)
i am not 100% sure whats involved, but probably a waste of time as you can get controllers that bring up the 32's response time with the 4wd..
what i can tell you is putting the 34 Getrag into my 32 was probably the best modification to date (engine rebuild will probably win now). it was costly when i did it. i spent around 8k including a clutch.
its reminded me of the days when i had a close ratio box in my Gti-r. i don't know about others but i just seem to like close ratio boxes..
As for power handling of the getrag, don't believe what you hear they are strong boxes!! 500hp at the wheels with a fair bit of abuse and still good :(
hope this sells your box :P
  • 1 month later...
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
