Hi all,
Just wondering if neone could tell me what this is or what they think it is. Basically i can only here it at idle and very low in the rev range as its not that loud just irratating (Spelling). Its coming from the engine bay and sounds to me like a leaking exaust manifold but it did it before i got my extractors and now it still does it with the new ones and new gasket, i changed the oil and its still there? someone once told me that its normal for Double Over Head Cam engines to do this but i disagree, the car still runs fine and isnt lacking in power its just really starting to annoy me.
Ne Help Much Appreciated.
Cheers
John
https://www.sau.com.au/forums/topic/21687-ticking-sound/
In my old 202 it was the hydraulic lifters, and my GTS-T makes this same sound. I was told cheap oils can make your car do this, but I have been running fully synthetic in mine, so Im not too sure whats going on. Anyways, It never hurt my 202 and my 33 is going strong.
https://www.sau.com.au/forums/topic/21687-ticking-sound/#findComment-461315
could be hydaulic lifters.
I have been told that Mazda's have a bad problem with this, and they have a special oil additive to fix it.
Put it in with the oil run for 20mins until noise is gone, then drain oil. Apparently it (oil) comes out black, thick and lumpy. Basically the additive is an internal engine cleaner.
Ask your friendly Mazda dealer about some
https://www.sau.com.au/forums/topic/21687-ticking-sound/#findComment-492424
"yeah i always get bad fumes in the cabin if sitting in traffic for a while. gives me a saw throat after extended preiods, im assuming its not real good for you."
N/A_R33,
mate you have an exhaust leak, go to an exhaust specialist and have it checked out...they will find where it is...
i had the same problem with a previous car, after changing the exhaust manifold gasket many times and not fixing the problem, i discovered that the manifold face was warped and not sealing properly...
had the manifold machined and problem fixed!
Cheers
https://www.sau.com.au/forums/topic/21687-ticking-sound/#findComment-492624
i had it checkd and it seems one of the 'rear' bolts for the exhaust manifold is missing, sposedly this is a common problem in 33 gtsts and 95% of the time people dont bother replacing them as its a huge job, i can definitely hear the clicking of the air leaking but as far as power/econoy nothing seems to be affected, two different tuning shops told e not to worry about it unless it starts to get worse, any suggestions ? anyone know how much it usually costs to get the bolt fixed ?
https://www.sau.com.au/forums/topic/21687-ticking-sound/#findComment-492731
I got mine engine tap tap tap last month when cold start, noise gone when warm.
On way back from GOR cruise, my car misfiring ratatatata hard on 3rd gear acceleration. The next morning oil pressure running low, car has flat spot everywhere but that cold start tap tap tap noise totally gone....... what the?????????
Car is slowly getting better and better to drive, but still a bit flat spot and won't make boost on 1st gear (gauge only goes to 0). Now boost only comes in 2nd gear or higher (gauge goes to a bit over the halfway mark between 0 & +7).
On cold start, oil pressure will go past 6 mark on +/-1200rpm idle. When warm, on 700rpm idle oil pressure is a little less than 2. When driving around 2500-3000rpm oil pressure is about 4, and cruising 4th gear 60kph about 2000-2500rpm the oil pressure drops to about 3 or 3.5 mark.
Strange..... very strange......
https://www.sau.com.au/forums/topic/21687-ticking-sound/#findComment-494048
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
