Hello guys/girls
Just wondering if anyone knows the difference between them?
did some research on them but couldnt find much, only this.
GTR 32 was only up to 1992
GTR 32 v-spec came out in feb 1993
GTR 32 v-spec II came out in feb 1994
does anyone else know any more info of the difference?
https://www.sau.com.au/forums/topic/216877-gtr-32-v-spec-v-spec-ii/
in '94 the R32 was only produced in GTR version...
GTS and GTST finished in '93... that's when the R33 GTS and GTST started, you'll find also that R33 GTR was first released in '95...
[year after '94 - (R32 GTR)]
http://en.wikipedia.org/wiki/Nissan_Skyline_GT-R & http://en.wikipedia.org/wiki/Nissan_Skyline for most of the info your after.
IIRC V-Spec II was the only R32 GTR produced in 1994 and has some features from the R33 GTR (faster attessa, clutch config etc.)
In actual fact the R32 GTR was built along side the R33 well past 94. Nissan do this regularly, continue a known model along side the new one.
Of course I dont expect you all to belive me. I just happen to have contacts in Japan who know this stuff, and Im not willing to make a big deal over it. Who really cares if they stop production in 93 or 96 anyway?
Edited by MYRB30
I have only ever seen one R32 GT-R tagged as a 95. It was a 94 build, but first registered in '95. So carried that info on the auction sheet.
R32 GT-R’s
Gross production quantity
43,934 units
Production quantity classified by type 40,390 control vehicles
NISMO 560 unit
V specifications 1,453 unit
V specifications II 1,303 units
228 N1 based specifications
Under carriage number division GT - R NISMO (marketing quantity 500 units)
Under carriage number 100000 – 100560
Prior-term type: 1989 August 21st -
Under carriage number 000051 – 017466
Mid-term type: 1991 August 20th -
Under carriage number 212001 –
Latter-term type: 1993 January -
Under carriage number 300001 - 314649
Register quantity of classified by year type
1989 system (1989) 4,555 units
1990 system (1990) 8,426 units
1991 system (1991) 7,081 units
1992 system (1992) 7,961 units
1993 system (1993) 6,204 units
1994 system (1994) 7,465 units
Standard setting body color Prior-term type
Gang ray metallic (KH2)
Jet silver metallic (KG1)
Dark blue pearl (TH1)
Lead pearl metallic (AH3)
Black pearl metallic (732)
Mid-term type/latter-term type
Crystal white (326)
Spark silver metallic (KL0)
Prior-term type 1989.8.21 Debut at that time price: 445 ten thousand
It comes after ƒnƒRƒXƒJ and ƒPƒ“ƒ?ƒŠ and it debuts the victory of group A as a purpose as 3rd generation GT-R
Total length 4,545mm?~ full 1,755mm?~ total height 1,340mm wheel base 2,615mm
Vehicle weight 1,430kg
The highest output 280ps/6,800rpm largest torque 36.0kg-m/4,400rpm
Engine type RB26DETT total cubic displacement 2,568cc
* Adoption of twin ceramic turbocharger
* Electronic control torque split 4WD (ATTESA E-TS) adoption
Adoption of *4 wheel multi-link suspension
Adoption of *225/50-16 inch tire
ƒjƒXƒ‚ 1989.3.11 Sale at that time price: 441 ten thousand
560 units were produced as a Gr-A evolution model.
* Turbine wheel material of turbocharger from ceramics modification to metal
* Adding the air intake to the front bumper
* Addition of hood top mall
* Modification of side sill protector
* Addition of small-sized rear spoiler
* Abolition of rear wiper
The abolition of *ABS
* Abolition of air conditioner
Abolition of *I/C grille
* Vehicle weight 1,400kg (the light weight conversion of 30kg)
Mid-term type 1991.8.20 Sale at that time price: 451 ten thousand
* Addition of side impact door beam
* Driver's seat SRS air back option setting
* Addition of seat belt warning light
* Adoption of shocking absorption steering wheel pad
* Adoption of interior resistance to flame conversion material
* Modification of headlight lens and H1 conversion of valve
* Vehicle weight 1,480kg (the increase of 50kg)
Latter-term type 1993.2.3 Sale at that time price: 454.5 ten thousand
* Clutch structure from push system modification to pulling system
Modifying rear diff. cover form from the *94 model
V specifications 1993.2.3 Sale at that time price: 526 ten thousand
Commemorating Gr-A3 year successive victories, it sells
* Total height +15 it makes 1,355mm
* ƒuƒŒƒ“ƒ{ corporation make brake caliper - and adoption of rotor
Adoption of *BBS aluminum wheel
Tire adoption of *225/50-17 size
* Vehicle weight 1,500kg (the increase of 20kg)
V specifications II 1994.2.14 Sale at that time price: 529 ten thousand
Commemorating Gr-A4 year successive victories, it sells
Tire modification to *245/45-17 size
* Adoption of private sticker
N1 At that time price: Control vehicle based 430.5 ten thousand V ƒXƒy?[ƒbƒNƒx?[ƒX 509 ten thousand
V specifications II base 512 ten thousand
It sells as the pace vehicle for N1 durable race/lace participation
* Adding the baffle plate for brake cooling
* Headlight from projector system modification to suspicious looking 2 light systems
Also the based vehicle respectively simultaneously with *V specifications ¤ V specifications II sale modification
From *V specifications base turbine wheel material of turbocharger from ceramics modification to metal
i got a 1993 april model no brembos..... so methinks its non v-spec... did the 93,s have any upgrades whatsoever?? i was told that they had a slightly better crankshaft? can anyone confirm?
Yes the oil pump drive was changed on the later model R32's & is better. Don't know exactly when, however.
I had a thingo that tells you how to read the build plate on a GT-R. Can't find it, however surely this stuff is stickied somewhere. That many people ask it isn't funny.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
