Gday
just got a stock r34 gtt from japan and would like to replace the dodgy cassette player with an mp3 cd player (nothing special, as long as it plays mp3 cds and FM radio it's fine)
Don't feel confident taking the headunit apart myself nor do I know which replacement unit to get so I'd like a quote from an experienced skyline audio installer to supply a decent replacement mp3 cd player (with fm radio) and the installation
I'm in the inner west (camperdown) of sydney
Sorry forgot one thing .. the new unit should also have an ipod connection at the front so that I can plug my ipod straight in without any messy adapters etc
Can anyone atleast recommend a headunit like that?
i think sony has those xplod ones taht sell at supercheap that have an ipod plug in the front, ((saw them last time i was there getting a tarp lol)
and i think pioneer do one aswell
both are mp3 players.
best thing to do is just go to WOW or auto barn of what ever, and look at the range, and buy the one that you like the look of, instead of asking for others opinions :)
yeah I've found a pioneer one at the local strathfield (I think it was strathfield) car and audio store .. approx. $300 with installation .. has the ipod plug at the front too (not aux in) I'm sure I could find something slightly cheaper but it's not worth the hassle cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
    • Luckily for safety applications, with dedicated links not being used for any other traffic, you simply run ProfiSafe (or an equivalent safety comms protocol from other vendors) over the top of ProfiNet (if that's what you're using, or Ethernet IP if you're stuck in the world of American PLCs and not verking vis ze Chermans) and the redundancy is more about being able to know that you need to cause a system diagnostic lockout because you've lost one of your comms channels, rather than not knowing that you've lost your only comms channel. Granted, heartbeats and all that are possible and useable and all that, but some safety applications are are so time critical that you might not be able to afford a few milliseconds until the next check.
