OK, I have a question about IC piping. What are the different materials that can be used and what are the benefits/disadvantages in using different materials.
Also, i need the piping made in 60mm. What are the tightest mandrel bends I can get?
Also, any reccomendations of a place to get it done on the coast. Looking for best value (eg cheap but good job - what we all want eh!)
thanks in advance for any help.
https://www.sau.com.au/forums/topic/2169-ic-piping-material/
Mild steel:
Cheap
Easy to use
Rusts on the inside and outside if no coated
Mid weight
Mild heat soak
________________________________________________
Stainless Steel:
Expensive
Harder to use and cut
Will not rust and can be polished to mirror
HeavyHigh heat soak
Aluminium:
Mid / high price
Easy and hard to use, joins must be spot on for welding
Willnot rust and can be polished to mirror
Light
Low heat soak
Personally go for alloy if you can and have someone to weld
it for you. If not use mild steel and have it powder coated or
HPC coated for heat treatment.
DriftKing Performance in Bris can do nice piping I believe.
https://www.sau.com.au/forums/topic/2169-ic-piping-material/#findComment-41282
pete
i was having a look around for dump pipes for the gtr and everyone wants to sell mandrel bent ones for 600 bucks.
so did some looking around and a 90 3' mandrel bend is 9 buck so for a total outlay of about 80 buck i can make my own.
also i want to try a few combos on the zorst with a twin 2.5' system and compare it to my 3.5' system
only use stainless if you want the look( doesnt make you go faster )
alloy would be the goods but you actually have to be a good welder to do that **** so might just stick to the mandrel bents
its all good fun
if you need anyhelp give us a bell
040926626
pete
https://www.sau.com.au/forums/topic/2169-ic-piping-material/#findComment-41407
Gday Pete
I agree mostly with boosty but i must admit prefering stainless steel in the real world.
As far as i know Ally mandrel bends and welding all up i think its gonna cost u double, I think it will be easier for ally to polish but thats about it..
Ultimately Ally would be best but no way i could afford it and i did my full pipe setup from turbo out to plenum for $200 including carton of crownies for tig welds and polished myself :-)
https://www.sau.com.au/forums/topic/2169-ic-piping-material/#findComment-41428
reason i wanted to do alloy is that there is a guy here in tweed that does it and quoted around $500 which i think is good cos he will do all the work... or i can lower the cost by cutting it myself..
i dont wanna do stainless due to $$$ and not mild cos I dont know anyone around here that does it.
and it all depends on when i get my redundancy money thats been owed to me since november 01....... but if i get what im meant to i might just go for the 1UZ (toyota soarer v8) coversion, so i can have a 200kw hilux surf :)
https://www.sau.com.au/forums/topic/2169-ic-piping-material/#findComment-41537
The last lot of piping I made was for a friends gtst. I used mild steel and as mentioned above cut it myself and marked the joins then taped the pipes together. Then took it to the local exhaust shop who actually oxy welded it (looks awesome) total cost for 8 welds + 6 welds around the ends to stop the pipes blowign apart was $35 (theye just charge by the hour @ $35/hour)
Not bad I thought and it looked good. Then we had the inside cleaned and the outside powder coated in metalic silver.
https://www.sau.com.au/forums/topic/2169-ic-piping-material/#findComment-41711
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
