Tein Spanners
Guest Boxhead
I ordered one of these spanners from autobarn(hey i have contacts so i dont pay retail) basically after my initial adjustment of my suspension i was thinking maybe i could send my spanner to a fitter and turner i know to get some more made up... if anyoen wants one, ive heard that 1 spanner does the lot as in its just one spanner for all models... so register your interest and i will see what i can do, also, if you can tell me how much you willing to spend to see at what i can do if there is quite a few of you...
Michael
[email protected]
https://www.sau.com.au/forums/topic/21694-tein-spanners/
YOu can buy after market C Spanners adjustable type from good tool shops such as Tool Works at Castle Hill 02 9894 6546 or Wholesale Suspension in Penrith from about $40 each and fit all coil overs.
On the topic of Tein though and prob a lot of other Jap made coil overs they are often too hard for Australian road and race tracks and for that matter even the smoother Japanese tracks. The Japs don't always get it right.
I have the Tein HA adjsutable shock and height Teins and found the rear of my Zed TT to be quite hard even on the softer settings, It over steered a lot and did not brake as well as should as well as got unsettlesd over bumps such as turn three down the hill at Eastern Creek. I took out one fo the front and one rear and sent of to Eibach, who only make the best springs in the world probably. Anyway they dyno tested the shocks and found them to be quite hard even on the softer setting especially the rear. The springs in rear were also too hard. Factory around 250 pounds and the Tein were 570 pounds. They changed to a twin spring, the heavier being a 440 pound spring with a Tender spring of prob 150 pounds. Bottom line 3 secs a lap faster and did a 148 with a passenger ( Akira) who also has hard Teins in his car. Much nicer for road cars also.
Guess what Skyline Teins have even heavierr springs,both GTR and GTS-T yet the cars are lighter so guess what, "Good is the Enemy of Better" If you have coil overs and think your skyline handles well it can be much better and if a zed passes you at the track then consider. he he.
https://www.sau.com.au/forums/topic/21694-tein-spanners/#findComment-518460
Guest
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
