  • Replies 83
the guys at Autobarn noarlunga are great, couple of the guys that work in there own imports so i find them very helpful. 2 of the guys in there own skylines so i always ask them if im not sure about anything.. Never had any trouble with them, but yeh havnt shopped at the mile end autobarn, except to buy my clublock. Not going to shop there now.
I ducked into a Repco shop at lunchtime and saw in the specials bin a Clublock for the "discount" price of $56. :(
Too bad BigW sell them for $34 everyday price. :domokun:
I ducked into a Repco shop at lunchtime and saw in the specials bin a Clublock for the "discount" price of $56. :down:
Too bad BigW sell them for $34 everyday price. :banana:
the big w ones take 10 secs to saw of... =/
yeah and Kietz should know with all the experience he's had :D
Hmmm, and you know this how? :bunny::)
The Repco and BigW clublocks were identical, same packaging and all, same item. Big $ difference.
And 'yes' they are handy for beating thieves! :D
didn't read the whole thread but all i can say is that you can't get any good help anywhere these days, anyone can walk into these 'specialty' shops and get a job...whether you know shit about a car or not. Most the people that work there are only there to push buttons on the cash register. however, having said that, not all of them are dumb.
Ive learned that if you want a job done properly, you do it yourself. enough said.
In saying that not all of us are mechanically minded bro.....hence most of the time you get people with knowledge to do it for you and you pay for it....
i went to Autobarn the other day and asked for a set of copper spark plugs for my 33 with a .8mm gap and the lady serving me had a quick flick through the book and told me 30 bucks each! then i kindly stated that copper plugs are around 4 buck each and she gave me a blank look as if i was talking sh*t... :)
Floor mats, seat covers, airfresheners and oils.......thats about all autobarn and supercheap are good for.
Can't believe you younger fellas buy parts from either of these mass outlets, you're paying a premium for crap!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
