Anyone have problems with this company I ordered a part of them they still have not posted,then I got a mate to email and ask for the same part and was told they have them in stock yet my part has not been sent,I have tryed contacting them but still no response has anyone else had trouble with them,as I starting to think they are running a scam :down:
Cheers Dertoid
https://www.sau.com.au/forums/topic/216969-rhdjapan/
Maybe this might help...
This was on their site;
4/28/2008
Japan has entered Golden Week. All of the major makers our closed down until the 6th of next month. Our warehouses will still be open but our employees will be off on the 29th, 5th and 6th. All days other than those days we will be shipping as usual, posting parts, and tending to requests. Pat and Russell will be on business trips most of the week meeting up with partners and tuners but will be responding to emails. Sorry if we are a little slow to respond during this time but rest assured the RHD team is behind the scenes tending to each and every part in each and every order as usual.
https://www.sau.com.au/forums/topic/216969-rhdjapan/#findComment-3831529
  • 4 months later...
Anyone have problems with this company I ordered a part of them they still have not posted,then I got a mate to email and ask for the same part and was told they have them in stock yet my part has not been sent,I have tryed contacting them but still no response has anyone else had trouble with them,as I starting to think they are running a scam :cool:
Cheers Dertoid
We are far from running a scam, all of our business information and contact information is clearly listed on our site and we normally answer all e-mails within 24hrs.
https://www.sau.com.au/forums/topic/216969-rhdjapan/#findComment-4158733
I have so far avoided ordering parts from you for our business (Red R Racing), due to the fact i sent you a lengthy e-mail explaining to you who we were and what we do and the fact id like to do business with you and recieved no reply. Now that you are a member on here and a bit more accessible i may decide to include you guys as part of our suppliers.
Paul Diemar
Red R Racing
https://www.sau.com.au/forums/topic/216969-rhdjapan/#findComment-4158786
The guys at RHD have been more than helpful with the things I have ordered from them. Out of however many hundreds of orders they put through on the huge range of parts they have, some part for some customer might be a bit late. Not a nice feeling but sit tight man I am sure you will recieve your stuff.
Definately not a scam!
https://www.sau.com.au/forums/topic/216969-rhdjapan/#findComment-4158849
Paul Diemar
Red R Racing
Thank you for the heads up. Please provide us with your e-mail address so that we can see what has happened regarding your e-mail. Sometimes e-mails from new accounts get caught up in the junk filter and I apologize for this.
https://www.sau.com.au/forums/topic/216969-rhdjapan/#findComment-4181708
Red R Racing can be contacted at [email protected]
https://www.sau.com.au/forums/topic/216969-rhdjapan/#findComment-4181717
Paul Diemar
Red R Racing
I have also sent at least 5 different e-mails this year enquiring about several products but never received a reply from RHD.
I found Greeline.jp very prompt and reliable, with products , once paid for, coming within a week
https://www.sau.com.au/forums/topic/216969-rhdjapan/#findComment-4188925
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
