Hey all
I am thinking of bying a bike and need your advice on what exactly to get for the first bike
I was actually chosing between the cbr 250 and ninja 250... what would you say be better for a beginner?
Im also open for other choices, but from what i know these two are the top choices in 250s
And im a girl, so looks DO matter :rofl:)
https://www.sau.com.au/forums/topic/216987-advice-please/
i too am looking at my first bike and from what i have found and ahve been told is the cbr 250 id the best learner bike around. there reasonably cheap, look good and they are quick.
so if i were you id look for a good cbr and go for that. i know thats what im doing.
:rofl:
https://www.sau.com.au/forums/topic/216987-advice-please/#findComment-3831045
Quite a few of my mates road Zeals on their L's and P's.
Good, sensible bike. The engine is torquey across most of its rev range, unlike the CBR 250RR which needs to be revved all the way to its 18000RPM redline to go anywhere. Its reasonably small and light, which is great if you're not big. The chassis is pretty benign, with very predictable handling.
Does your state have L and P plater restrictions on bikes? That will also factor into your choices.
https://www.sau.com.au/forums/topic/216987-advice-please/#findComment-3831053
Hey all
And im a girl, so looks DO matter :D)
Personally? Honda VTR. Looks like a Ducati Monster but smaller. Has all the 250cc advantages plus:
Low-ish weight: 140-ish kg dry, a few kg less than most others in the class
Not a faired bike: When you accidentally drop it for the first time it will cost you much less.
V-Twin: They're torquier down low (ha on a 250 :) and easier to come to grips with than an inline 4.
What you probably want to do is go ride a bunch of them before you purchase - you might
find one thats "you" more than the others. Get your L's: try out learner-legal mates bikes;
do a riding course that lets you try a few different bikes out; or test-ride at a store if you can
convince them :dry:
Regards,
Saliya
https://www.sau.com.au/forums/topic/216987-advice-please/#findComment-3831665
the best advice i can give you is to buy a cb250, as your a learner your new to the biking lifestyle your more than likely to have an accident i know i did and it wasn't even my fault. cbr250rr are overpriced import that is close to 20years old, these bikes are imported given a lick of paint and sold as a newish bike there nothing wrong with that but its like buying a skyline.
https://www.sau.com.au/forums/topic/216987-advice-please/#findComment-3831950
ZZR250's are great, that was my first road bike. Stay away from bikes that that to peaky in revs or power delivery - not fun to drive in traffic. as suggested ride a few to see what you like. A good alternative is the road trial (i.e. the DRZ above) - allows you to mount kerbs with ease and more comfortable at traffic speeds (nice to haev the upright position.
lots of choice, don't spend too much (likely you will throw it up the road at some stage)
most importantly - GET THE BEST TYRES AVAILABLE! yes they will cost, but worth every penny...
https://www.sau.com.au/forums/topic/216987-advice-please/#findComment-3832324
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
