Hey Guys,
I dunno wat the hell is wrong with my car. i gatta an R32 GTS-t and lately wen i rev it up it start farting between 5-6000 rpm i dunno why? so could you plz help me with this matter. ill appreciate your help guys. one more this and correct me if im wrong, i think it might be my injectors problem, and it cant be the spark plugs coz i know wen they cut off, (a cylinder wont work at all so the car will become a 5 cylinder) any way ill be waiting for your comments.
Thanx :P
https://www.sau.com.au/forums/topic/21699-farting-5000-rpm/
i have an r33 so dunno what u mean by farting.. but when i started modding my car between about the same revs as you my car would pop u could really feel it and it would lose power on each pop... this is misfiring... the fix i found was to regap my spark plugs down to 0.85mm... if it had of continued doing it after trying that it would have been my coil packs... popping is always not enough air(or too much fuel) because basically its the liquid fuel that didnt ignite coming out the exhaust causing a 'pop; where as 'ticking' is not enugh fuel/too quick-a-spark which requires retardation of ignition timings (detonation)
hope that helps :D
https://www.sau.com.au/forums/topic/21699-farting-5000-rpm/#findComment-461783
