Rb20det R32 Wiring Loom And Ecu With Remap And Safc2= Rb25det Start Key And Go?..what Are The Pitfalls?
Hi there,
I just got a rb25 with no wiring loom or ecu and i want to put it into my r32, just wanting some experiances... one of the main ones is will it run with a r32 loom and remapped ecu and safc2.
I want to retain my gtr injectors on the rb25..anyone know a place where i can get a custom fuel rail??
What modifications need to be done to make the rb25det run well with r32 loom and ecu?
thanks
posted in wrong sect. before sorry.
i have a rb25 in a r32 its well worth in i have a std r33 ecu and loom if i had the chance again i would not do it this way 1k just on wiring
hmmm no plugs are different injectors, tps, afm etc etc.
i just put the rb25 block and head, manifolds and changed all the sensors over , fuel rail and injectors etc to keep the 32 rb20 ones, then got the ecu remapped and running
then starting changing injectors etc
i used rb20det balancer, and steering pump...fitted up perfectly, and also used rb20det loom and comp, no worries!!... just modified the injector wires! IMO way easier than shoving a rb25 loom in and fiddling under the dash what not.
Cheers.
i used all rb20 sensors also.
I got burned with that too. I am running the following
RB25 DE head from R33 (VCT)
RB30E bottom end
RB25 injectors
RB20 CAS
RB20 ignitor
RB20 coils
RB20 temp, oil pressure, knock, start sensors
rb20 everything else.
I had to chop the top feed connectors and fit rb25 side feed ones.
I wanted to use top feed injectors but they would not fit under the plenum no matter what. even without the fuel rail they are too tall.
the whole lot is running off an R32 ecu that I have remapped. it runs like factory, returns 400kms per tank and makes 260odd rwkw.
the R32 ecu can be made to run many things.
i run a 25 with 25 loom and 32 ecu... the wiring side of things is not overly hard and takes around 2 hours to do it properly, thats everything and wipers hooked correctly so everything works.
I much prefer this rather then swapping everything over to rb20shit
In regards to injectors, i used the rb25det injector loom and plug, and made my own plug from the ecu side to fit :thumbsup: .
Edited by RaZ_TuRbO
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
