Alcatel Speedtouch Home modem (external). Compatible with all local ADSL providers, and a great little unit. Apparently will support up to 1.5Mbps downstream. Was my ADSL modem for 2 years and worked brilliantly, however as I am no longer on DSL, no longer require the modem.
Best thing about this one, is that its been BIOS upgraded into the "pro" version, which means that it can function as a full router for your home network. Plug it into a hub or switch, and any device connected to the switch can connect transparently to the Internet. No longer requires RASPPOE login to your ISP via windows each time you turn on your computer. Just set your login settings via the web interface of the modem, and the modem will be permanently connected to the Internet.
Asking $120 ONO.. If interested PM or [email protected]
https://www.sau.com.au/forums/topic/21702-adsl-modemrouter-melb/
Dlink aren't up to the same standard as Alcatel I'm sorry.. nor are they are a router for that price..
Price up a DSL modem and a router and see what you come up with :P It won't be $100
anyway, *bump*
  • 3 weeks later...
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
