hey guys,
im not exactly sure what has been done to the car before i bought it, but i was told the HICAS had been removed, (lock bar or just completly gone, i have no idea)
but now this little problem has started where my steering is reasonably straight untill i hit approx 80km/h and then i have to turn my wheel atleast 20degrees clockwise to keep the car straight
during the 70-80km/h range theres a deep sound coming from the rear tyres
any ideas???
https://www.sau.com.au/forums/topic/217023-hicassteering-problem/
stick you head under the back of the car and have a look to see if you actually have a lock bar installed. it will be just behind the diff.
i have no idea what the lock bar would look like, im not really experienced with this stuff, all i know is what i explained.
if i do have a lock bar, would u know what the prob is, or vice versa??
Sorry to hijack your thread, but for those who know.. if your odometer doesn't work.. does it affect your hicas? I have the light come on and the steering gets really hard every now n then, its tempermental..
James: I removed via a lockbar.. if you remove the steering rack you need to put something in its' place to hold the tierods (things that adjust toe and/or are used for steering) or the back wheels would flop about a hell of a lot :/
You can get lock kits such as the tomei one which retain the steering rack but use an arrangement of washers to lock the tierods in place.
Karina: Yes it will affect HICAS and the speed sensitive steering. When the little needle on the end of my speedo cable snapped and I thus had no speedo, I had to drive around with heavy steering until I put a new cable in when I installed my new dash.
I now have a lockbar in the back, no HICAS solenoid thing in the engine bay, removed all the lines. Have also got a 25 box and a 280kmh speedo, I get the HICAS light on the dash after 1-2mins of driving but my speed sensitive steering is still there.. I believe if you unplug the HICAS ecu in the boot you will lose the speedo sensitive steering..
Edit: oops just realised you said "odometer", does this mean the speedo still works but the odo doesn't??
Edited by bubba
hey guys,
any ideas???
hey there,
my friend and i both had this same exact problem. his was while he had hicas and mine was after i removed hicas.
the cause is air in your power steering lines.
you may have a leak which is causing air to get in, but chances are slim since the system is high pressure and you would see oil everywhere or your hicas light would stay on in your cluster. give it a couple days of driving and using the steering wheel, and it should bleed itself out. otherwise, open the power steering cylinder cap in your engine bay and turn the wheels side to side for about 10 mins. if all else fails, flush the system and start over.
hope that helps,
dave.
I pushed the trip reset button one day and it just stopped working. Steering got heavy from then on and the hicas light starting coming on more often. Speedo works fine.
if you unplug the hicas harness, the steering will stay stiff. you have to snip the green wire with the white trace line on the bigger harness to disconnect hicas without damaging anything.
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
