I went to this one in Moorabbin a couple of weeks ago.
Apparently it is the longest track in Australia. It was pretty awesome. Its pretty close to Southland on Chesterville road. From memory we paid $40 for 15 laps.
www.gokartsport.com
https://www.sau.com.au/forums/topic/217044-go-karts/#findComment-3832427
www.gokartsport.com
at lemans its sumfin like 25 or so for 10 min and in 10 min u get bout 15-22 laps
https://www.sau.com.au/forums/topic/217044-go-karts/#findComment-3833770
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
