Hey guys, im just new to the site. Bought my R33 GTS-t last week. So firstly i would like to say hi to everyone :D
I live down south and i parked in a collonades carpark and went to far into the cement block on the carpark >.< theres a small crack in the front bumper that i have just covered with black tape for now. Does anyone know any good fibreglasses in the southern area that they would recommend?
Thanks, Nathan.
https://www.sau.com.au/forums/topic/217054-fibreglass/
Welcome to SAU mate.....i personally wont really worry about that little crack...let me ask is it a stock front bar or aftermarket.....also be very careful with speed humps, gutters etc while parking and stuff.....
https://www.sau.com.au/forums/topic/217054-fibreglass/#findComment-3832209
It's an M spec front bumper. and it has been scraping quite a bit, the bumper looks frail as its starting to splice and splinter :S is there anyway to heighten the car a small bit because a new bumper would be quite expensive. its exactly 100mm off the ground.
https://www.sau.com.au/forums/topic/217054-fibreglass/#findComment-3832531
if it's just a stock bar then your ride is too low! get some standard springs or something
Yeah its not a stock bar, im affraid if i put stock springs on it, is going to look like crap. Any other suggestions? maybe i could get a new front bumper thats a bit higher?
https://www.sau.com.au/forums/topic/217054-fibreglass/#findComment-3835032
pm sent mate
im based down moana area
im a fibreglasser and also sell bodykits/performance gear and a heap of used skyline/nissan spares
my website is in the making
check this image to see my work i have just done with fittment/paint on his 180sx which still isnt done yet
pic isnt the best phone camera
more pics on rpm lounge if you want to view them
https://www.sau.com.au/forums/topic/217054-fibreglass/#findComment-3835988
Get used to it :D cheapest option. crawl over bumps and humps, its the way of the enthusiast
https://www.sau.com.au/forums/topic/217054-fibreglass/#findComment-3836873
pm sent mate
Sweet as man, PM sent. I think i saw that 180 @ the castle plaza - westlakes cruise.
Does your shop have a leather cover (thing that goes around gear stick, not sure what its called :D) mines a bit torn.
Thanks!
https://www.sau.com.au/forums/topic/217054-fibreglass/#findComment-3836967
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
