I want to buy a Exhuast system for my R33 4door non turbo
im getting some prices on a few stianless steel japanese systems
what i wanted to know if anyone has put any on there own car
and how loud is it
when i rang a few places they told me it would be to loud if i bought a HKS and other sorts of brands of exhuasts
thanks in advance
https://www.sau.com.au/forums/topic/21706-question-about-exhaust-systems/
i think whoever told u HKS zorsts where loud has a few things to learn, i have a HKS System and it is not very loud at all, it basically just gives the car a really nice deep note, doesnt drone, and still has all the performance benefits.
i have a 5zigen cat back, 2 3/4 inch, it could be a turbo exhaust im not sure, but its drony and loud only between 1500-2000rpm
Rest of the time its more then fine.
My car has this very distinctive exhaust note and this nice throbbing, any one else have this. Im sure its from the RB25 engine :D
hey nismodified - the throbbing ur talkin about - ive got it too! sounds pretty good eh?
do you get a different, louder sound generally when cold and in lower revs? kindof a slapping, throbbing through the zorst - cause i get that for bout 5 mins every morning - neone know what that is?
i dont get that sort of noise, but i know of another Rb25DE that does have a similar noise u described
mine has a very deep note, but its hard to describe since im always inside the car when it revs thru the rev range :(
ive been thinking about making myself a straight thru pipe for sometime now..
within the next few weeks i have access to this computerised oxy cutters and welding gear, i should be able to cut some flanges out of 5-10mm metal plate....2.5" piping wont be hard to get,...weld me up a straight through pipe....for off road private use of course
I got a simple muffler fitted to my car for pure fx, coz i have no money, the muffler is 2.5inlet and 5" outlet, it makes a hell load of noise but in certain parts of the revs, ie: 2000-3000 main offender, it makes a shit crackling/snapping noise, i have NFI what it is but it ruins what is otherwise a really sweet sound.
i like the crackleling popping noises ;) but thats me
it happens to me usually when i back off the throttle on decent revs.
It should be cause by unburnt fuel passing into the exhaust system.
A simply solution to get rid of the popping, if your not using 98octane fuel, then a switch to optimax, synergy or ultimate may clear up or at least reduce the noises.
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
