Anybody got any info on FJ20ET injectors? I'm told they're 370cc, and I gather they're hosetail items.
Thats as much as I know. Hoping for a Nissan part number, JECS/Zexel/etc part number, Bosch equivalent/replacement part number, any of this sort of info?
Anybody got a picture of one?
These appear to have been the gun upgrade for HR31 RB20DET's back in the day, basically straight fit and a decent flow upgrade.
https://www.sau.com.au/forums/topic/217079-fj20et-injectors/
Don't know for sure if they fit RB20's or not but if they do u might be better off with 13bt 550's instead. Bit more expensive but more room for improvement. I have 4 standard FJ squirters u can buy if u do decide to go down that route anyway. Only part number I could find on them were 2744 3917A.
Cheers, Vaughan
getting some 440cc GTR injects. arent too hard either... i see them all the time for about $350 a set of 6.
there is a safe way of attaching them to hose tail type connection .
you need to dremel 1mm deep by 4mm long off the circumference of the lower part of the 'shank' insert part below the original 0-ring
this gives the hose clamp some 'bite' to stop hose slipping off end
just use brand new hose and clamps to be safer again....
