So after recently moving and going from one lot of spares to two lots, we have no room and need to get rid of some stuff!!!
Tyres
No longer needed as I sold my 17" rims - we now only have 18" rims on our cars so they are pretty useless!
One set of four semi slicks - Yokohama Advan A048's - 235/40/17. 80% or more tread left - medium/hard compound. (photos further down in thread)
$385.00
One set of Porsche Cup slicks - 24-64-18.
aka 240-40-18. These are almost completly new. Again used for only one practice session. new tread depth is 3.1mm the LOWEST on these is 2.4mm.
so around 15% worn on average. (photos further down in thread)
$600 a set.(4) ($550 each new)
R33 Stuff
Cusco 6 point Safety 21 roll cage for a R33 Gtst - Steel one, bolt in not weld - decided I can't be bothered and it was a bit of a impulse buy. Bought it off another forum user... its used, ummmm might be missing a couple of bolts from memory but Il replace them before pick up.
$500 ono
Walbro 255L Fuel Pump (GS-342???) ready to bolt into a 33 Gtst.. comes on the std bracket.. ran out of power for my car, prolly did around 4,000 kms over 12 mths..! Was ok at 300+ rwkw but only with the gain turned down on the boost controller
$100 firm
Exedy 5 puk clutch - used for about 3000 kms... hardly worn, couldn't hold the 300rwkw... was fine at 270rwkw though! (photos further down in thread)
$300 ono
Std Flywheel - Just removed from car - twin plate setup reason for removal.
$100 ono
32 GTR SHTUFF
NPC rebuilt OS Giken TS2 twin plate clutch - Basically brand new except the splines are damaged on the friciton plate (riveted hub needs replacing on one of the plates) - push type $500 firm (photos further down in thread)
Gearboxes -
R32Gtr push type - partly disassembled, suits rebuild or anyone chasing a bell housing, input shaft is smashed - although you get all the smashed bits with it :thumbsup: - $250 (photos further down in thread)
R33 Gts-4 push type - 3rd gear is blown, (higher strength, extra ribbed bell housing) doesn't include transfer case - $350 (photos further down in thread)
R32 GTR Bonnet - couple of minor superficial dents/marks... 500 ono - photos next week as the bonnet is stored elsewhere and I need to get there on Monday after Texicana
RB26 Long motor - this will be rebuilt with forged internals, looking at expressions of interest before starting, buyer to have input on internals etc which will vary cost. Please PM your enquiries to Dave aka T04GTR and post in this thread so I can tell him to log on and check it out!!
Random - DR30 Coupe complete doors minus the mirrors, manual wind up windows, red & black trim, red and silver two tone duco - from a RS model. $500 for the pair.
Please PM or post here if interested. Willing to post smaller items, roll cage and tyres etc pickup only unless you can organise your own carrier.
  • Replies 46
Im keen on the good semis sould fit my 17*9 rims ok?
Hey Brad,
Yup, I had them on the zeddles which has 9" (well one is 8.5" :) ) rims.... no dramas :rofl:
EDIT: Spoke to Dave before, he used to have them stretched over his 9.5" rims on his GTR
[/u]R33 Gtst hard intake: Hard intake for standard turbo or whateva is the same? I have had this HPC'd in a candy blue colour - was on my car when I was still running a hi-flow and AFM... $50 Firm
Do you have a picture of this installed on your car?
I'm curious to know if it will fit on the Stag.
  • 3 weeks later...
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe will give me my power goals and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
