  • Replies 46
Exedy 5 puk clutch - used for about 3000 kms... hardly worn, couldn't hold the 300rwkw... was fine at 270rwkw though!
$300 ono
still got it??
will pay now!
NPC rebuilt OS Giken TS2 twin plate clutch - Basically brand new except the splines are damaged on the friciton plate (riveted hub needs replacing on one of the plates) - push type $500 firm
where is npc at?
how many kays since rebuilt??
cheers
where is npc at?
cheers
NPC are in QLD.... although you don't need to get it repaired there. Although would be the cheapest option.
http://www.npcperformance.com.au/
1500km at most.... splines were damaged due to faulty input shaft... uploading some photos now..
npc rebuilt (jacobson spec plates)
os giken ts2bd. (not damperd anymore)
post-19586-1211797006_thumb.jpgpost-19586-1211796902_thumb.jpgpost-19586-1211796749_thumb.jpgpost-19586-1211796510_thumb.jpg
the "g box" one has the dammaged spline. pulled out due to motor rebuild. drove fine but upgrded to a r3c.
advan 048 semi slick race tyres.
20% worn. $385 a set. ($450 each new lol)
235-45-r17. medium/hard compound.
these have been used for 1 practice session at barbagallo.
porsche cup car slicks.
24-64-18.
aka 240-40-18.
these are almost completly new. again used for only one practice session. new tread depth is 3.1mm the LOWEST on these is 2.4mm.
so around 15% worn on average.
$600 a set.(4) ($550 each new)
6 available total. (2 on hold.)
also available is the rear. big ass gibson gtr size. (if you can fit 275's under the rear of you car these will fit.)
27-68-18.
aka 270-45-18.
also only about 15% worn.
350 a pair.
post-19586-1211800073_thumb.jpg post-19586-1211800894_thumb.jpg post-19586-1211801011_thumb.jpg
r32 gtr gearbox partly dissasembled.
smashed input shaft. suit rebuild or gearset upgrade.
r32gtr gearbox smashed 3rd. complete un-opened.. suit gearst upgrade or rebuild. still drives fine with no noises except no 3rd lol.
in the first post theres the 32GTR box and the 33GTS-4. but you've listed 2x 32GTR boxes?
is there a typo?
interested in the 33 box but not the price.
hey there
20% worn meaning theres 80% left still??
thanks
is there a typo?
They are one of each, but are the same thing. Only difference is the 33 bell housing is more strengthened than a 32 one. Both are push type, both suit a 32 GTR...
Pm offer, these boxes are Daves not mine so it isn't my call :down:
hey there
thanks
Yes, there is still 80% left :down:
ok, first post updated as of 6.6.08....
All irrelevant posts of mine have been deleted to clean the thread (ie sold items)
Cheers
Anna
If they are not picked up i will take them, need to be sent to Vic though
Hey Roy,
no dramas, il let you know if they don't get collected :)
Can work out freight etc then
mind shooting me a pm of the Rb26 please ? :( thanks! :D
no dramas, Il get Dave to send you one today. :rofl:
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
