Hey guys/girls,
Ive had a few mods done to my R33 and whilst the car was on the dyno, the clutch started to slip. It made 221.6rwkw and now its time to upgrade the clutch. Ive read the thread in the Driveline forum, but everyones opinion varies. Im leaning towards an Exedy Heavy Duty Cushion Button clutch, just wanted to know what clutch people are using that have similiar power.
Thanx
https://www.sau.com.au/forums/topic/217097-time-for-a-new-clutch/
i cannot believe that people still come on here and ask about clutches.
two words people
JIM BERRY
thread now can be closed. :laugh:
Just doing a hi jack the pic in avatar is that the GTR you guys had in autosalon mag i think it was in 04 pulled that out the other day was clean in the mag
Hi,
I have a used Nismo single plate copermix clutch. This is really the ultimate single plate clutch and perfect for your power level. It has done less that 1000kms. Rated to 420ps it is a lightweight clutch and flywheel unit. Most clutches will do they job but will kill your gearbox from shock load. This clutch will look after your box for a long time.
More info here
http://www.nengun.com/nismo/super-coppermix-clutch
Call me if you want it.
Asking $800 firm.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
