NO!!
they are good for popping airbags. think there are 8 or so on these so I would only use a meter in them. if it is a LED one then that is a different story. still prefer a meter.
jon,
I'm bored so I'm tearing yours to bits.
Dammit! I'll leave it to you then. I can't wait to hear the result....
  • Replies 44
NO!!
jon,
Cool...hope you find more cool stuff! The G35 guys keep on talking about their remotes ability to wind down all four windows by just pressing the unlock button 3 times and holding it...I tried but no dice...
partial PDF from the 05/06 service manual.
that is relevant to what we are talking about.
its missing a relay so the whole concept of adding a switch is a myth. there is more to it that that. I would say: fuses,relays, switches,seats.
I'll know more over the next day or so.
jon,
you may want to stay away for a few days whilst I find this missing relay :)
g35sedan_heatedseat.pdf
Ok my 04 coupe is a 70th and has the seat warmers,
you can push the switches up or down, what is the difference ?
up is for high heat, down is for low
as in the thicker and longer bar for up, and thinner and shorter bar down low
can you do us a favour and open you console and take a pic of where the wires go form the switches?
its as simple as
- pull down the plastic around the bottom of the shifter
- pop out the pin
- lift off the gearknob
- lift up the armrest
- then lift the console from where the switches are
this takes about 2-3mins and requires no screwdriver or anything
i would just like to see on a coupe where the wires go after they coem out of the switches
thanks mate!
Warren
warren,
easier way.
remove covers on seat bolts. remove 4x14mm bolts position seat so it lays back out of the way:(DO NOT DISCONNECT IT!)
look at 4 pin white plug in middle of seat. it has 2 wires: a heavy red and black in it for the seat power ONLY. IF it has 4 wires going THROUGH the plug into the seat itself then you have heated seats.
based on the 05/06 sedan passenger seat you will have a LT GRN/BLK & GRY/BLU in that plug from teh car side - those will match with the ones in the centre console
the car (in the case of the 05/06 sedan I have here) is set up for them its a case of swapping seats, adding switches and finding the relay and fuse for it.
jon,
yours is wired for it but thats it.
Edited by Chris Rogers
just to update this..
i have found a company that sells carbon fibre heating elements
http://www.heatedseatkits.com/index.html
costs $180 for the pair for front seats
they are OEM items in many cars in the USA..
and i've also recieved my heated seat switches from the G35 :)
so once my exams are over, my plan is to find out if i have the heating elements or not, and if i don't i'm going to look at getting a set of heating elements and wiring them up using the stock switches to control it
it should suit those cold summer mornings just fine!
haven't checked as yet..
i'm studying for exams which are on friday which means i can procrastinate all day on the computer and be guilt free (as my notes are open in an adjacent window), but if i leave the vicinity of my computer/books (ie to go to the car) i get massive guilt about not studying..
i know i'm weird
i will check for the wiring before i think about getting any elements though
Just noticed my car has rectangular marks where the heated seats buttons should be. Seems to be a lump there on both sides of the console. Does anyone else have this? Looks kinda dodgey.
yes I have these too.
Unless the vehicle is equiped with heated seats there will be covers in place of the switches. So 99% of 35's will have these covers.
on some of them the covers are knockouts. in the case of warrens car they are visible but not punched.
warren,
re: question - yes.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
