set it at 68% to give yourself a buffer
set lag around 12
It should be a bit rich based on the ratios but the extra couple of percent covers for differences in the linearity of the injectors, if that makes sense.
keep an eye on the knock. If it's a bit high, bump the injectors up another couple of percent
12 positive.
so even with injector correction at 68 it's still rich? You can usually chuck a 550 single pintle in there with no correction and it will idle pretty well, slightly on the rich side maybe, due to the lag difference between the stockers and the new ones. I'm surprised yours is running rich
