hey guys
lately iv been noticing a few r32 gtr around with abs removed,
i was wondering is it worth removing, what benefits are gained by removing??? (yes iv searched)
also iv read its wired up inline with the 4wd, so would you remove it with out upsetting the 4wd??
i would also like the ugly thing along with the lines out of my engine bay
https://www.sau.com.au/forums/topic/217146-removing-abs/
No matter what the car is used for.. ABS is your friend!..
The only logical reason i would see for taking the thing out is weight.. even then.. the extra 15kg your going to loose.. you will loose ten fold worse when you lock up and slide off the track/race line..
Would you remove the seatbelts for weight?.. Leave it in.. ESPECIALLY if you drive it on the road.. I would NEVER go back to a non ABS car every again.. not that in the future cars wont come with ABS as standard..
https://www.sau.com.au/forums/topic/217146-removing-abs/#findComment-3839638
I have r32 gts4 and the abs unit was removed by the previous owner, i have no idea why. When i got it, i removed the abs lines, fitted a gtst master cylinder and engine bay brake lines and pulled the abs light from the dash. You still need the abs sensors on the hubs for the 4wd to work correctly.
I dont mind not having it as i have never had an abs car, but after driving a friends gtr in the wet, i would definatly keep it if i did the same car over again.
https://www.sau.com.au/forums/topic/217146-removing-abs/#findComment-3862646
A compromise is to relocate the abs to the boot if you need space under the bonnet (or a large single terb is cooking the unit). Have seen this done to 2 cars now and speaking with the owners it's not a huge job.
you can rob most of the parts out of some model of z32, they have the abs unit in the rear i think, or all the lines go to the rear first or something, i have a mate that did a similar thing
https://www.sau.com.au/forums/topic/217146-removing-abs/#findComment-3866844
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
