hey ppl, got timing belt, water pump, idler pulley, tensioner and cam seals changed on my r32 gtst, mechanic put it all in, test drive went good, on the way back heard a 'crack' type noise and then engine started coughin etc.
pulled it apart found belt 1 tooth out.... how does this happen ???
i trust the guy enough when he says he checked everything, has this happen to anyone before
result is loss of compression on piston 2 and 6, head comes off, finds out 2 inlet valves on 2 and 6 bent ! doh !!
thanx in advance ppl
Edited by jvs007
https://www.sau.com.au/forums/topic/217155-timing-belt-jumped-1-tooth/
The only real way a belt can jump is a tooth is from lack of tension or incorrect alignment to start with. If the tension is correct then the teeth stay in mesh with the sprocket. Which belt did you install? Did it have the timing marks on it so that it is easier to align? Hopefully it gets fixed well and you have no further problems.
When u install the timing belt and lock off the tensioner one side is actually tensioned more than the other, and this uneveness causes it to move one tooth on startup. Sounds like your mechanic put it on and didnt turn the motor over to even out the belt tension out before checking the alignment of marks (lazy). I found in many old RB30s that I had to line up the belt with one tooth out up on the cam for it to line back up properly when the tension became even
Edited by Jmaac
It will probably just come down to how it was installed as Justin has said. The installation of a timing belt is pretty basic but you just have to take your time and make sure it's done right. It basically consists of just removing everything until you can get to the belt. Take off the old one, replace idler and tensioner and put the new one on with all of the marks in the right place. You then rotate the belt around two or more times and while there is still some tension on the belt tighten the tensioner. Then put everything back together. This is a simplified way of how the manual says to do it. You need to rotate the belt around so that the teeth of the belt mesh into the sprockets otherwise you get the situation explained by Justin.
Good Luck
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
