hi all!
i need help with my window lifter module. i want the windows to shut when i lock the doors. the window module is activated by an earth signal. the existing wires are: - constant charge and - earth when unlocked, charge when locked (opposite to what i need)
this is the switch i have made:
the new wire is on the control rod for the lock, which earths when it locks by running into the strapping. this mostly works but it also earths when the door is bumped - closing or driving over bumps. it's a short pulse but enough to close the windows.
anyone got any ideas? i thought maybe a capacitor to filter the pulse, or a relay but not sure how to do it.
i would appreciate any help...
thanx
hal
https://www.sau.com.au/forums/topic/217160-auto-window-winders/
you asked me via PM about this:
firstly thats a door actuator so there is an alarm in there somewhere. do you wnat to use the remote control to wind up the windows or the key?
if alarm. find the wire that goes to GND when you remotely lock the car. stick a diode (1N4004 will do) with the band side facing the actuator. if you are doing it with the key only I need to see the lock timer (drv kick panel).
i was using the remote but my alarm/turbo timer means that when i lock the car the windows don't activate until after the timer finishes, and then several seconds later the immoliser kicks in.
i don't want to walk off with the windows down. it also means that if you turn the car off the windows go up when the immob starts automatically. which sucks if you're waiting in the car.
that's why i'm changing to the door locks themselves - that way they only lift when i lock the car - remote or key and not when i don't want them to...
nup. only just got into it. i mustn't be doing it right.
i got the bc639 --> i've got the collector grounded, the base connected to the lock wire (live when locked) and the emitter on the trigger wire.
so far the windows aren't going and the pass door locks aren't following the drivers side lock.
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
