Hi all,
Tonight adam (chefstagea) and I have got about 90% of his frount mount intercooler installed into his S2 stagea... Just got the last piece of piping to go and we have a slight question about it:
On the stock piping their was a small nipple with a black line going to it... Ive seen some intercooler kits which have these nipples on the new piping. Adams kit doesnt have the nipple on the piping. What does this nipple do? Im thinking ill go get one put into the piping while hes at work tomorrow. Where can I get the nipple installed? (exhaust shop maybe?)
the nipple I'm talking about is the one you can see here on the middle piece of piping:
Cheers,
Chris
https://www.sau.com.au/forums/topic/217176-frount-mount-intercooler-question/
On a series 2, you will need 2 nipples. One for boost and the other goes to the power steer pump.
I used a brass screw in nipple found at most auto parts shop. Drill a hole, and screw it in. The alloy pipes are fairly thin so I used some liquid metal approx $8 tube to fillet around the nipple and the pipe to make it stronger.
How to install nipple into a Intercooler pipe:
What you will need:
Brass threaded nipple fitting, with a 1/8 BSP tread on end (Sprint Auto $4.95)
1/8 BSP tap kit (from motortrader $37). This kit is needed as thread on nipple is a gas thread, thus it tapers
White plumbing tape
3mm Drill bit
8mm Drill bit
Heat silicon/sealent
Procedure:
Mark the spot that you would like the nipple with a scratch
Take 2mm drill bit a drill a pilot hole for the 8mm
Drill out hole with 8mm drill bit and more it around a bit to make room for tap
Tap 1/8 BSP thread into pipe
Place 2/3 layers of plumbing tape around the threads on the nipple
Screw nipple into piping and fastern firm but not over tight as intercooler piping is a bit soft could easily pull threads out
Place some heatsilicon/goop around bottom edges of nut on nipple just to ensure the seal is 110%
Happy days!
No finish Installing your frount mount intercooler, with one less thing to worry about :D
One more step, make sure you clean the inside of the pipe very well after to make such there is no metal bites from drilling. don't want them going thru the engine.
No need to buy expensive taps, as the thread is tapered it will cut it own thread, esp in the alloy pipe.
  • 10 months later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
