I've got the reversing beep too...like the trucks have. Also on another note...does anyones tiptronic beep when shifting gears? I could have sworn mine beeped during gear changes when I first got the car but doesn't do it anymore...or maybe I'm just hallucinating??
I'm quite sure the beeping speaker is in the steering column. Same beeper used for when you leave your headlights on and when you leave the key in the ignition and open the door.
I'm going to try to open it up tonight and cut the wire. Hope I don't set off the air-bags or anything.
looks like i must be the only one with only 1 beep when the gear (6MT) is put into reverse. But I had the optional Momo steering wheel, thats prob why...
I'm keen as to get rid of my reversing beeps as well, I'm confident that it is controlled by the BCM (Body Control Module).
Chris, please let me know if there is a way of removing it without effecting the headlight & other neccessary warnings, once you get hold of this new tool :thumbsup:
  • 2 years later...
Chris, please let me know if there is a way of removing it without effecting the headlight & other neccessary warnings, once you get hold of this new tool :)
On a previous car I got rid of the beeping by simply finding the damn beeper and filling everything with silicon and letting it set.
Basically muffled the noise right down as in the absence of air there was no noise transmission and avoided any risk of screwing up some obscure electronic system that may or may not be present
My 2002 gt8 has the beep too, just curious as a I had a instance on 2 seperate occasions recently where I had the battery and park brake lights come on and a Japanesse girl spoke too me, by the time I got to Nissan to get codes from the computer it had cleared.
Would cutting the wire to this speaker remove the instance where the girl will speak to you?
Does anyone else find it amazing that no matter how old a topic is, someone manages to dig it up from over 3 years ago and everyone else continues to reply as if it was yesterday's news?
*cuts some slack* I remember the first time I discovered a message board I posted on pretty much every topic I thought was relevant without considering the date of the last reply... and for what it's worth, it was a daihatsu enthusiasts forum.
To keep this reply on topic to the original post.......
Reverse beeping is a feature commonly found on automatic equipped vehicles.
Filling the speaking with silicon will silence any other warning signals (ie lights left on, door open)
Cutting the reverse signal wire will stop your reverse lights from working.
My experience with consult is limited to 90's models.
figuring consult will turn it off.
Can you really turn features on and off using consult?? Edited by daisu
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
