Hey guys i recently stuck my car in to get tuned, they reached about 9 psi and started to have issues with knockin.. etc scratched their heads for a while and worked out that the air fuel ratio was changing dramatically between runs without them changing any settings.. between high 10:1's to low 12:1's on boost
my mods are intank walbro fuel pump, power fc, fmic, full exhaust n a blitz ebc.. ive tried earthing the fuel pumps earth to the battery and the results remained much the same
any ideas would be greatly appreciated
Cheers
Jarrod
https://www.sau.com.au/forums/topic/217183-varying-afrs-on-dyno/
yeh i would of liked them to have done this but i wasnt there as i was at work, had a mate take it up.. the ppl that dynod it turned out to be completely useless coz they could of chekd the coilpaks n pressures while it was on a dyno, n i don't want to have to send it to another place n another dyno just to get the problem resolved, just would like to know some of the most likely causes.. the earth wire on the in tank fuel pump is exposed n a little corroded.. that couldnt be causing the issue could it?!!
located in perth guilt-toy, thanks for the pointers guys ill probally replace the fpr first and over the fuel pump becuz its the cheaper one to replace... are they any fpr's that are direct replacement that dont need adjusting? is the sard one any good?
It goes in this order
Test
If broken
Replace
Dont just go replacing random parts dude, test them, find the problem and then fix it the first time rather than bringing more problems into the equation
you said it was doing it under load, you must therefore test it in the same fashion
You 'can' do it on the street, but you wont be able to see the AFR's without a wideband and a proper read out.
Take it back to the dyno place and demand they do a semi-reasonable job. They did a half assed one last time
yeh i got a wideband with a datalogit.. i rang up the shop this morning n askd why they didnt test the fuel pressure n they claimed coz they were borrowin the dyno they didnt have their tools with them to do it ... so now i have the dilemma of sendin it to another shop with a dyno to diagnose.. why im tryin to just fix it myself coz all the shops in perth seem to be useless..
anyone know if a 180sx fuel pump will work in a r33 gts-t?!? i borrowed a girl my stock one because she thought her one was broken n claimed several ppl said it was the fuel pump so after we installed the fuel pump for her we found out she had a kink in her fuel line, when and got home, i tested her fuel pump n it still worked.. id swap them back sooner but shes in bali for a while .. so would it be fine to test a 180sx one in the skyline for a run to see if the afr's hold more steady on the wideband
ahh think i might just buy the new fuel pump.. standard wiring isnt the best anyway the earth wire is exposed and a little corroded so ill buy a full replacement one... so tomei or nismo?!! i know you probally can't go wrong with either but what one would allow for more hp?
Cheers for all the advice aswell guys
hey guys sorry to bring up an old thread but im still having afr troubles, i bought a new tomei fuel pump to replace the walbro, no change still playing up... bought a sard adjustable fuel pressure regulator.. same results...varies between 12 n 14.4 around the 6psi mark... and varies between 9.5 and 12.2 around the 10 psi mark... im measuring the results with a innovative motorsports lc-1 hooked upto a lap top... has anyone else got any other ideas that could cause the results to vary so much
Cheers
Jarrod
Edited by jarrod83
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
