Safe Afr
Alright I was just wondering what is the leanest afr you guys would consider safe. Basically I have a stock rb26 with no boost restrictor, exhaust and a FMIC, so the boost is around 15psi. had the car on a dyno and the afr ratio was mostly in the high 11s and low 12s but spiked at about 12.9. Is this getting pretty dangerously lean? Thanks for any help. Also what AFR would you recommend tuning to when I get PFC?
As NYTSKY said you 11.8 is safe! Don't risk it with 12.9!! I know many tuners that tune with afrs like yours but it is risky and to have many horsepower!
Better safe than sorry!
If you have with 15psi 12.9, try 12psi or less!!
Buy a PFC or remap your stock ecu. It is cheaper than to rebuild your engine!!
:rofl:
Edited by GreeceS13
If its a 10+yr old RB26 i'd stick to 13-14psi, likely the turbos will leg go for a start
Second, ensure not only getting a tune/ecu you also have a look at fuel pump, pressure, injectors (might be one slightly blocked etc)
So the stock injectors should be good enough to keep up with the 15psi? Also is anyone sure what the boost is without the boost restrictor on a GTR? My car is swapped so I am not positive that the turbos are stock, since i got the motor with 30k on it. though I am pretty sure cause they appear to be stock. Also yes it is a stock computer. Fuel pump is a walbro 255lph so I would think it would be fine. I am gonna get it back on the dyno in a couple weeks and take another look at the afr.
A print out of the dyno sheet... power vs AFR & power vs boost would be able to tell me if its dangerous or not. The first one would help if thats all you have.
  • 1 month later...
I will post a dyno sheet when if i can get ahold of one. Also what should the stock wastegate boost pressure be for the stock turbos? my car is boosting between 15 and 18psi. seems like that is higher than it should be.
12.9 isnt dangerous if you have timing to match, which out of a stock ECU shouldnt be too bad, but still dont drive it hard, i'd get it tuned properly first. that said i have seen cars (R34 GTR is the first one that comes to mind) that came out of racepace and was on a dyno elsewhere, its A:F ratio was 13:1 up top, and i believe thats just how it was tuned. i quizzed the dyno operator on it and said he'd seen it a few times from racepace adn it works fine, just less margin of error for crap fuel etc.
point is, i wouldnt say its bad if racepace is doing it (that said i could be entirely wrong lol)
 Share
    • Thanks to @V35_Paul there is an oem stereo available on gumtree, but the fascia is slightly different. It has a flip up screen as opposed to my pop up screen. Am I able to disconnect the radio/cd player from the fascia to use it on mine?
    • Had to google what a quart is lol.. so rough as guts a litre. That's a bit excessive, also what oil weight are you running? The whole steam cleaning idea isn't too far fetched either. Maybe as you suggested, turn off the WMI (assuming your Kebabtech pulls timing, boost, etc.) and run it for a bit and see if there are any noticeable changes in spark plug colouring.
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
