Nitro champs this weekend @ WSID. Starts Friday with group 1 first qualifiers @ 5.00pm.
All catagories will be well supported. I know for a fact that Top Alcahol has a group of 11 cars.
Will be crewing for Aaron Hambridge so come say hello. hoping for solid 5.60 or even high 50 to qualify.
https://www.sau.com.au/forums/topic/217196-nitro-champs/
Fifties for the win!
https://www.sau.com.au/forums/topic/217196-nitro-champs/#findComment-3835168
Well awesome but busy weekend. went out for first qualifier on friday afternoon and went 5.72. this qualified us third. unfortunately we dropped an intake valve so that was our night done. pulled engine down, replaced bore liner, full set of pistons, rings and bearings. welded and repaired cylinder head, cleaned bits of engine out of everything else includind oil pump, dry sump, and blower. had car running by 11am sat morning. had first elimination at 5pm. ran 5.65 @ 248mph for the win. then seviced car for next round. Up against wayne Newby in semi final, red light by .02. overall good result considering the start of the meeting.
https://www.sau.com.au/forums/topic/217196-nitro-champs/#findComment-3841697
saw the 5.65...well done
also saw the cherry Vs Newby...tough one...well done Stuey!
I see you crew for all the top teams in Top Alcohol and Sport Compact :(
https://www.sau.com.au/forums/topic/217196-nitro-champs/#findComment-3843563
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
