Its @ Racepace. no go :geek:
:bomb_ie: no fun i wan see the 26 in the 31
put me down as a maybe please :P as long as i can meet someone somewhere (just look out for an excel haha)
done why do you wana meet some where??
I'll be there supporting both the A Team and B Team! >_<
So put you down
I'll be there, possibly head down to shep saturday.
If we can get a few people to chip in for petty then we'll all go in ryans car....not that he knows yet.
No worries champ. the 180 will be cramped with more than 2 though.
if you all chip in enough i will enter and you can have the couch to follow me around with a trailer.
My chips don't have that many zeros... We could go in my SS although the cel would be heaps better. I've never been in one.
I won't be making it to sandown to watch the morning session but will be at the BOMBARDIER CAR PARK event in the arvo. Does anyone know where this is? like address that I can look up?
EDIT: just found it on the events schedule.
im in narre and wouldnt mind goin down there wif people as i dont really know many people there. ne one wanna meet up at krispy kremes at fountain gate? and if so wat time as it starts at 9am at sandown
if i knew i could of given u a lift
well i dont think you would of wanted to drive down to the gul & then all the way back the other way but thanks anyways
dont think i would of been able to last the whole day, not feelin 100% after last night lol
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
