I bought some Bendix Ultimate pads ($99) and Motul RBF600 fluid ($35) yesterday and fitted the pads in my garage after work. Put the wheels back on and checked it all over then realised I forgot to bleed the brakes. Took it for a drive and it doesn't even need bleeding, pedal feels great!
Now... if only I remembered to fit those backing plates to stop the low speed squeal :D
Edited by benm
https://www.sau.com.au/forums/topic/217270-brake-fluid/#findComment-3836889
Well why would u have to bleed the brakes if ur changing ur brake pads? u only have to bleed the brakes if you are doing a brake fluid flush(which is supposed to be done every 2 years) or if you have air in the system. Some people undo the bleeder valve when they are compressing the piston back in, this prevents putting pressure on ur master cylinder etc but other people just suck abit of fluid out of the resevoir(to stop it over flowing) and compress the pistons which pushes the fluid back up. If you are doing a flush you would suck most the fluid out of the resevoir, fill it up again and then bleed each corner(starting from the furthest away from the master cylinder) and suck the fluid through till u see a difference in color. Just keep an eye on the fluid level coz if u suck the resevoir dry u are well maggoted and is a pain in the ass. As for topping up the fluid it should say on the resevoir cap whether to use dot 3 or dot 4
https://www.sau.com.au/forums/topic/217270-brake-fluid/#findComment-3840639
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
