Hey peoples
Ok so obviously my car (r33 gtst s1 rb25det) is playing up so i'll get to the point lol.
Symptoms:
1. engine knocking? basically when i sit in my car on idle or driving it sounds and feels like somone is playing the drums under my bonnet.
you can feel a jolt and hear a repeating thud. thuds are random not continuous.
2. Sometimes when i accelerate, espesially when the engine is cold it reacts wierd, jolting back and forth before kicking in and taking off.
Its as if it trys to go then stops, then goes.
3. Exhaust sound? hard to explain. its definately louder, kind of crackily, sounds like a wrx. not a nice note. sounds rough.
4. I have a few gauges installed in my cabin. One of which is an air / fuel ratio. I generally ignore that gauge cause its always jumping from lean to rich
as i drive around, but recently it's been noticably different. When driving around if i'm not accelerating or in idle the gauge says i'm running
completely lean. Basically as far into lean as it can go. sometimes the red marker disappears.
This is obviously a concern for me hence why i'm asking for help.
My thoughts were possibly coil packs? spark plugs? injectors?
Really not sure. my best mate, who also drive an r33 gtst claims to have had the exact same problem.
He replaced his coil packs and it solved the problem. apparently.
I have acquired a set of splitfires to test with. I assume there the right model as they say ecr33 rb25det on the box.
Please let me know your opinions, advice or any experiences you've had which appeared the same
problem as mine and how you overcame it.
Thanks heaps
Guesty
https://www.sau.com.au/forums/topic/217277-my-r33s-sick/
I've got an N/A GTS-4, so obviously it's a bit different to your car, but I was having similar problems, though not to the extent that you've got
Anyway, I pulled that black cover off the engine and checked out the coils, and one of the plugs had worked itself a bit loose. I just pushed it back on until it clicked, and now my cars running a lot better, but still not perfectly. I noticed a few things were fixed such as:
-No longer get a strong petrol smell every time I start the car
-Car runs a lot smoother. Hard to explain, but it kinda used to feel like every road I drove on was covered in potholes. That feeling is now gone
-Exhaust note is better, but still makes a bit of a rattling/fluttering sound
I guess, in my case, one or more of my coils are stuffed, or maybe the plugs are dead from all the years of driving with them half plugged in
I would suggest to you to upgrade the coils to Splitfires. At least if the coils aren't the problem, then you'll have some nice new ones anyway :domokun:
Edited by jimnastic
https://www.sau.com.au/forums/topic/217277-my-r33s-sick/#findComment-3836327
I just then tested all my coil packs.
had the engine running and one by one, unplugged them to see if the idle would drop.
conclusion. my front 2 coil packs aren't working. other 4 seem to be working perfectly.
I actually have a brand new set of splitfires which i bought from autobarn.
one problem, they're the wrong type. there for a series 2 not 1. sigh.
on a lighter note i have a brand new set of splitfires for sale lol.
if anyones interested i'll let them go for $450 firm.
Edited by GuestyR33
https://www.sau.com.au/forums/topic/217277-my-r33s-sick/#findComment-3836421
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
