and ebay!
justjap rebrand them to the JJR
not the same turbo, they are shit, don't touch them, seals are made of jelly, and they seem laggier(!?). Stick with genuine KKR.
What when are you 25 boys getting the kkr430's to spool?
Yeah, fk me not another post like yours ey? :)
1. HKS turbos are not $3000.
2. That makes them nowhere NEAR 1/3 the cost, most like 1/2.
3. The poor man pays twice. You see threads of people complaining their car is laggy, unresponsive, they cant get traction because power delivery is poor with only 230rwkw etc etc, and then look at the turbo (and other parts chosen)... its simply not going to get any better that what they have.
Yes its appropriate in performance for the price, but it pays to ensure the buyer knows what they are getting into before hand.
Not everyone researches before purchase (the 15hp ebay chip thread from last week is a perfect example of this)
I stand corrected, they're just under $2500 delivered IF you manage to get it through customs without them charging you GST and duties. If you don't, then you're getting damn close to $3k.A KKR 430 is $850, which is ever so slightly over 1/3 if you aren't charged customs, and well under 1/3 if you are (which technically you should be). You also get a local warrenty with the KKR.
You see plenty of posts complaining about plenty of things. You also see plenty of posts here saying they're fine, I'm happy with it. I'd hazard a guess that those who complain "it's laggy" are complaining because they expect their $850 turbo to perform like a $2500 turbo, which is just plain stupidity.
By the way, my post wasn't specifically directed at you, moreso the clowns who say "HKS GTRS" (see 5 posts into the thread) with no rhyme or reason behind it, like it's just a few extra bucks to go for the HKS. For the record, I own an HKS turbo.
Edited by Ionos
From what i have read (was going to get a kkr) the better option is a high flow, bolts straight on and proven and easy to find.
i bought this one http://www.skylinesaustralia.com/forums/35...-9b-t22706.html and am nothing but happy with it.
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
