Hey guys, over the last few weeks i have been talking to a few people about whats happening to my 34, after speaking to a few of these people, im starting to think my 34 nismo is not an authentic one... is there any way i can tell, like check over the internet or something??
Edited by A31StRuCK
https://www.sau.com.au/forums/topic/217310-is-it-authentic/
if u bought from powerplay than its nismo
* GT-R - 2.6 L RB26DETT twin-turbo I6, 332 PS (244 kW, 392 N m) (advertised as 280)
* GT-R V-Spec - Additional aero parts, brake ventilation ducts, diffuser.
* GT-R V-Spec II - As above + carbon fibre bonnet with NACA duct.
* GT-R N1 - Blueprinted N1 motor, no A/C, no stereo, no rear wiper, basic interior trim. (only 45 made)
* GT-R M-Spec - Leather interior, softer suspension with "Ripple Control" dampers, heated seats.
* GT-R V-Spec II Nür - As above V-Spec II + N1 motor, 300 km/h speedo. (only 750 made)
* GT-R M-Spec Nür - As above M-Spec + N1 motor, 300 km/h speedo. (only 250 made)
* GT-R NISMO R-tune
* GT-R NISMO Z-tune - 2.8 L (bored and stroked) RB26DETT Z2 twin-turbo I6, 500 PS (368 kW, 540 N m) Z1 and Z2 (Only 20 made)
https://www.sau.com.au/forums/topic/217310-is-it-authentic/#findComment-3836910
It's not a nismo car, and technically speaking it's not really a nismo kit (although other's would argue otherwise)... it's actually an Aero kitted factory GTT. Sorry to say, based on my knowledge of GTT's you don't have a "nismo" car as per se.
https://www.sau.com.au/forums/topic/217310-is-it-authentic/#findComment-3836981
Might be on the auction sheet, but you probably won't have that. And I take it you don't have japanese service manuals? The thing is most imports are wound back... often more than once, too many points where it could be wound back ... e.g. in japan, at auction, in australia by the importer, in australia by the dealer. If the motor and body is in good nick be satisfied with that.. with all RB's it's all down to how well it's been serviced and looked after generally.
https://www.sau.com.au/forums/topic/217310-is-it-authentic/#findComment-3837004
ok also is there some way to find out if the 100 thou service has been done, obviously i recieved the car before 100,000 so there would be no stickers on the door or window... car runs smooth as but cant really push it as its due the service, but i dont wanna spend that money if its already been done ya know!
https://www.sau.com.au/forums/topic/217310-is-it-authentic/#findComment-3837043
If you're lucky there's a sticker that sometimes comes with a new timing belt, that gets placed under the bonnet. If you don't have one, then I suggest you change it (and the waterpump, and the plugs, and all the other things you do at the 100k service at the same time).
https://www.sau.com.au/forums/topic/217310-is-it-authentic/#findComment-3837049
Here is the quote I got from boostworx for a 100k service.
$170 water pump
$95 timing belt
$240 labour
$77 service / safety
$65 oil
$140 redline (tran + diff)
$55 coolant
$145 dyno
$140 platinum plugs
Whoa, man thats alot eh, i can get the parts for the 100 thou service for like $360... thats belt, bearings, water pump the whole lot!
then all i need is to get the oils and fluids then get someone to do it for me!!
anyone on here know how?
https://www.sau.com.au/forums/topic/217310-is-it-authentic/#findComment-3837065
Well that's the list price, and it's not really that much when you think about it - just shop around and you'll see. Especially given that boostworx found a AFM problem on the dyno (picked up a lost 15rwkw), and a front suspension bracket issue... good to see some mechanics still know their trade well.
But yeah if you want to save some, do the fluids yourself, the plugs even. Not really hard dropping the oil... undo the screw on the bottom of the sump, dump the oil into a pan, change the oil filter, put screw back on, fill up with motul oil, and bob's your aunty.. umm uncle even.
https://www.sau.com.au/forums/topic/217310-is-it-authentic/#findComment-3837075
there are certificates issued for parts fitted by nismo after sale but doubt you have them. Is there even such a thing as a nismo gtt r34? it was probably just a gtt some stuck a few nismo things on and said it was a nismo gtt? Did you pay a premium for the car because they claimed is was a "nismo"?
https://www.sau.com.au/forums/topic/217310-is-it-authentic/#findComment-3837167
