Well i went and saw Iron man tonight, it got relased today. Has anyone else seen it yet..?
I was pretty impressed..so thought id share that with u all LoL and tell u all to go and watch it!!
went and watched it last night as well, thought it was awesome....recommend watchn it
https://www.sau.com.au/forums/topic/217334-iron-man/#findComment-3837919
its not better than "horton hears a who"
https://www.sau.com.au/forums/topic/217334-iron-man/#findComment-3837932
Seeing it later today... been waiting a while for this sucka to come out.
Was simply awesome, everything I expected... hope there is a sequel, there was a spare suit :thumbsup:
btw, does anyone else play 'Stan Lee spotto' in Marvel Comic movies to? Gotta love the Heff :(
https://www.sau.com.au/forums/topic/217334-iron-man/#findComment-3840522
