Loved this movie. I saw it opening day as well, only thing that was missing and was a massive dissapointment ( i know it sounds stupid) but the song Iron Man by Black Sabbath wasn't in the actual movie and i just thought it would've been so much better if they had snuck it in somewhere.
Also just to point out, i went with a mate who is totally into the whole comic thing an he told me that the other suit is the one his mate wears later on (the black guy) and he is called 'War Machine' or something. Anyway really enjoyed it and was well worth it.
https://www.sau.com.au/forums/topic/217334-iron-man/page/2/#findComment-3852561
