Sooo.....its Friday`
Redsuns88
 Share
FTW = For The Win....a L33+ gamers terms.
So yeah friday, whoo!!! Long weekend, double whooo!!! Finished at midday, today tripple whooo!!!
What does "WFT" mean anyways?? I've seen it alot on here and never have had any idea what it means?
wtf = what the f***
ftw = For the win
edit: damn beaten
Edited by coffeeboy
Redsuns88 Where u at?
maybe go for a run down the coast to the casino :P
or just to the car wash my car really needs one hahahahaha :P
FTW = For The Win
WTF = Do You Want To Eat?
WFT = Web File Transfer / World Fisheries Trust
somebody gonna get a hurt real bad.....
he is hillarious. was going to watch him live, but was a bit pricey to go see his show. $80 a ticket.
i think carl baron is coming up for a tour soon
i got a flat tyre.. read my thread!
nope, I'm stuck till i get a new tyre. I WAS heading towards the sunny6 coast...
maybe go for a run down the coast to the casino :D
or just to the car wash my car really needs one hahahahaha :ban:
lol well im gonna wash my car too then hit the streets.. :banana:
edit- live in brissy mate.. near the city
Edited by Redsuns88
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
