what happened to the one i sent ya last year???
there are a few up at the local wreckers... will check price for ya.
I still have,
I didn't want to wreck it, (since it works),
a dead one is what I need.
Since my car is my daily drive, I need to setup MS in such a way, that I can go back to the original Nissan ECU without any hassle, ie setp MS over a weekend, If its not right by Sunday evening, I can put my old ecu back in.
I will be using the stock wiring, with some small changes (which are undo able) to allow MS to run.
this is what I'm going to do
http://forums.hybridz.org/showthread.php?t=133522
Nigel
Edited by noddle
HEY!
exacgtly the same idea i had!
any chance of a full write up later when its finished?
adn are you interested in making a kit for me? $$$$$
cheers
I will be keeping a record of how it will be set up, and will make it available when it's finished
as for doing it for some one else, I'm not sure at this stage,
I ordered my MS today, and hopefully it will turn up in a week or two.
Nigel
Definately can get one, just forgot to pick the damn thing up. Will try to remember this weekend when I visit my mate. Sorry bout that.
D
any luck ?
my MS is all put together now, waiting on some other bit now before I can install it .
Nigel
Your in luck... provided I can just remember to pick the damn thing up! I'm going to write ECU on my forehead with texta before I go over there again. Do you still need those axle bolts too?
Just the ECU, I will use the axle "nuts" off my "parts" mr30..
If you have access to a wrecked mr30, I also would like the airflow meter connector (cable with plug, from the harness) and the connector on the airflow meter hardware ( or the whole air flow meter), I don't need the air box or connector pipe.
we haven't worked a price out yet, send me a PM with what you are asking.
Nigel
  • 3 months later...
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
