what happened to the one i sent ya last year???
there are a few up at the local wreckers... will check price for ya.
I still have,
I didn't want to wreck it, (since it works),
a dead one is what I need.
Since my car is my daily drive, I need to setup MS in such a way, that I can go back to the original Nissan ECU without any hassle, ie setp MS over a weekend, If its not right by Sunday evening, I can put my old ecu back in.
I will be using the stock wiring, with some small changes (which are undo able) to allow MS to run.
this is what I'm going to do
http://forums.hybridz.org/showthread.php?t=133522
Nigel
Edited by noddle
HEY!
exacgtly the same idea i had!
any chance of a full write up later when its finished?
adn are you interested in making a kit for me? $$$$$
cheers
I will be keeping a record of how it will be set up, and will make it available when it's finished
as for doing it for some one else, I'm not sure at this stage,
I ordered my MS today, and hopefully it will turn up in a week or two.
Nigel
Definately can get one, just forgot to pick the damn thing up. Will try to remember this weekend when I visit my mate. Sorry bout that.
D
any luck ?
my MS is all put together now, waiting on some other bit now before I can install it .
Nigel
Your in luck... provided I can just remember to pick the damn thing up! I'm going to write ECU on my forehead with texta before I go over there again. Do you still need those axle bolts too?
Just the ECU, I will use the axle "nuts" off my "parts" mr30..
If you have access to a wrecked mr30, I also would like the airflow meter connector (cable with plug, from the harness) and the connector on the airflow meter hardware ( or the whole air flow meter), I don't need the air box or connector pipe.
we haven't worked a price out yet, send me a PM with what you are asking.
Nigel
  • 3 months later...
