hey guys, well my work is clearing out some stock and i was able to pick up these Warlock Central Locking Kits pretty cheap. I figured i would grab a few before they all went as im sure people here would want them for extra security etc. The model number on these is #2252.
Now im just reading off the box on these so this is their description.
4 Door Control System Unit
5 Wire Master Actuator X 2 pcs
2 Wire Slave Actuator X 2 pcs
Control Module
Cable Harness
Fitting Hardware and accessories.
Now you can use the 4 door kit on your 2 doors too i believe.
So hopefully i can help a couple of guys out. Only chasing $50 each for them, they cost my work more than that!
Cheers. Luke.
PS. Can mods please leave here as only want to sell to SA.
https://www.sau.com.au/forums/topic/217518-central-locking-kits/
i have 1 left. First in gets it, WLD MAN you have first dibs.
Krishy, im not sure if it will fix it, i have no idea about these, just saw them at work and figured some poeple will probly want them.
Sorry bro when on the rck cruise last night got a on the spot fine bit strapped for $$ atm, sorry
that sucks WLD MAN.
Ryan, on the box it states 'Universal Type/ Key or Button Operation / D.I.Y. COnversion Kit'
so from sounds of that you should be able to make it work in the ke70.
hahaha he does get a lot of attention.....wanted or unwanted lol....i think his gearbox is stuffed and something else wasnt going right that night.....he had total power loss after 100kms....but its a quick and nice looking car....how funny was all those commos through the hills and through the corkscrew.....i was laughin hard in the passengers seat being totally wasted lol
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
