carmate and jetspeed
hippy
 Share
Originally posted by hippy
anyone had experiences with their bodykits??  not really interested in their paintjob .. just the kits ... i'm getting a 400r bumper and a friend is getting cwest skirts for his supra ...
just remember, you may have to chop metal off your front bar.
Dont cut that front radiator support at all!!! Its there for a reason, there was a big thread on Bodgy kits with cut front supports, go look it up and you will soon change your mind
Sumo
Originally posted by SKYLINEGTR
for which out of your cars ?
Got it for my Lancer GSR, you can kinda see it in my avatar..
Carmate are the distributor's to almost all car places that sell these bonnets..
Originally posted by Nismodified
i was probaly the first R33 that Jetspeed ever put a kit on.
This was a while ago, i wasnt happy with the results and their professionalism (i.e lack of).
Things mite have changed since then, but i doubt it.
you are correct, nothing has changed
on the other hand, I got my CF bonnet from carmate also, top blokes really helpful.. even tho they said they had one in stock and didn't and I had to wait 2 weeks (box was labelled CF and it was fibreglass) it's top quality.. They import most of their stuff.
Originally posted by <<>>
i thought JetSpeed supplies their kits to Carmate
- negatory
u mean the primer? or the actuall paint?
Has anyone bought bodykits from jetspeed or carmate off the shelf n bring home to do u'rself? is it just me that their stuff is realli crap? u have the sand and file down lumps, fill in holes, sand down again then prime Again! but then still, most of the time it doesn't fit properly. Anyone else with this problem?
I get all my stuff from fibresports coz it's top quality
http://www.fibresports.com.au
e-mail me if u want prices
[email protected]
jetspeed didnt do any of the prep work on my kit, it was done by someone else, and they did a very good job and took alot of care. They also hate Jetspeed.
My kit sagged, was gaps....later i realised why they refused to give me a Jetspeed sticker (i didnt know shit at the time), they didnt want there bad workmanship displayed for all to see.
The kits dont kit properly because they are made poorly to start with.
Jetspeed make this particular rear bar for hondas, any honda, and from the many MANY cars in my area that have that rear bar, it looks like its One Size Fits all job.
Not uncommong for gaps measuring in INCHES, but this may also have something to do with the buyer and how cheap they are.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
