  • Replies 53
Yep. 2 Trade Plce Vermont. Ph. 9873 1722 Ric Kemp is "the man" but they all know their stuff. I see that you are in Geelong. Still worth a call and a talk to ric even if in the end he says go see someone closer to you. He knows set up better than anyone else.
Dj_L3thal,
You wont be disapointed.
im probably dropping 30mm-40mm (which is about an inch) we measured it there and it will look nice there and will get rid of the risk of my tyres rubbing the mud guards on full lock (i got 235s on the fornt and 255s on the back)
Interloper, i'd also suggest seeing chris at centreline in thomastown, they are awesome, sit you down, plan everything you want to do, work out best options/prices, great service and they definitely know what they are doing
WOW!!! just got the car back, i love the koni shock/king springs setup, i didnt get the fornt camber kit coz the money for that went into new constatina boots and bump stops etc as the ones from my stock setup were ****ed basically, but im happy as with ahndling, ride quality and looks, i do get scraping when going in driveways on full lock in reverse but if i go real slow it doesnt do it ;) i guess thats expected being so low, car dropped an inch from stock height all around
would definitely recommend this setup to everyone ;) so easy to change the stiffness of the front shocks too ;) but i think ill leave them on the hardest setting as its not too hard and definitely holds well around those hard corners :D
2 thumbs up
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
