Please Help! Vic R34 Gtr Engine # Doesn't Match?!?!
Hi I am planning to buy a R34 GTR private sale.
The steel plate with the VIN/Engine number in the rear left engine bay is stamped/engraved.
I read on this forum that if it is engraved then it might be stolen - factory plates have the details PRINTED, not engraved on them.
The VIN matches what Vicroads tells me, but the engine number is not the same as that stamped on the plate. The guy told me not to pay any attention to that as that was the stamp in Japan, and the engine number would be different in Australia?!?!?!
He is sure the engine hasn't been swapped.
The compliance plate is a red/mauve printed plate on the left hand side of the engine bay, about halfway down.
Just wondering what you guys think about this, is it dodgy? I was originally planning to buy it in the next few days.
Cheers. Any advice would be greatly welcome.
GEt the engine number off the block and call vic roads. If it has been registered before they will have record of it and can also tell you if it's a stolen motor.
The original engine number will also be on one of the ID tags in the engine bay. check that the number on the block matches that tag.
Engraved VINs are fine.
I've had a few cars like this.
And even if the engine number doesn't match (provided it passes a 'stolen' check) that's fine also, the engine could have simply been replaced (however, whether
you want to buy a car with a swapped RB26 is a different issue.)
Thanks that's good advice.
Dave1200, do you know where I can find this engine ID tag in the engine bay of a 2001 Series 2 R34 GTR non-vspec???
I didn't see any other tags apart from the VIN plate and compliance plate, but I wasn't looking for any, so I might have missed it.
Cheers.
Cheers.
Dave is right, it will be on the block also. Try the front to start with underneath the cams but if not either side by down through the gaps.
Found this thread:
http://www.skylinesaustralia.com/forums/N1...umber+R34+where
It might pay to use the software some of the guys have access to on here, think it is nissfast.
Can you PM me the car out of interest please. Don't worry not going to buy it instead!
if you call 131171 and use the prompts to check a vehicle....all you need to do is say the reg number and the recorded voice at the other end will tell you the VIN,engine number,date of reg expiry and if it been through the VIV system ect.......its a 24 hour system so you can do it anytime.....just give them the reg and it will sing like elvis giving anyone the details of your vehicle,i actually think its a breach privacy myself and shouldnt be allowed.....imagine the amount of false-e-fying you could do and shit you could get innocent ppl in
Edited by ylwgtr2
Before you hand over your hard earned. If you suspect it is stolen, look into it as much as you possibly can and if you find it doesnt match up then report the seller or just forget about it and look elsewhere, its not worth the loss if it turns out to be stolen.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
