  • Replies 183
Posted Images
Marty..
Battle 3 .. its Black STi vs Blue WRX (Not Black WRX) :)
Daz is kicking Brentons ass there not mine :laugh:
I am pretty sure i get my ass kicked by a girl in that round :banana:
Pete
Pete sorry about that was late I was drunk....
fixed now tho
Leewah...Deal with it :banana:
in the battle 2 vids of prpl 33 GTR vs 300zx, someone behind the camera goes "i never knew a slow car could do that"... haha thanks :D also i never realised that my na zed is loud enough to drown out a gtr from the other side of the skidpan hehe. nice vids btw Martin :P
i'll definately come up to watch/help out at deca masters... will be an awesome event and it's always good to watch the faster cars. hopefully uni exams are over before november 15th deca so i can have another go.
yeah paul said the same thing, it's nothing serious though which is why i kept driving. it's because the zed has pcv pickups on the passenger side cam cover so on hard right hand turns it picks up too much oil and it gets sucked into the plenum and smokes like a chimney... same thing happened at deca last feb but it was worse because the long wang was clockwise last time. not the best look when your driving around blowing smoke but my engine is actually very healthy compression-wise and doesn't burn a drop around town. i'm gonna change the pickups so that they're on the middle 2 cam covers when i get some time off uni and that will stop it from smoking next time :P
Your car was also blowing some pretty severe smoke in the arvo battles, in case ya dont already know... everytime you were on the opposite start block to me so i couldnt tell ya as you were driving off :D
Hanging around DECA threads a bit late at night aren't you Daz?
Wouldn't be waiting for the results by any chance would you?
Might just let you wait a little longer....... They are finished, but I need to confirm one result with Snowy in the morning and then I will post them up.
Yep I beat you all morning :P
Haha! :P
I saw a cone hit & a tonne of tyre smoke when he missed a chicaine!
That's a WD as the timing won't be accurate! :(
I'm going to fight for this one! :P
The one technical issue with your fight Daz is that the lock-up/missed chicane was on the 80% non-timed practise run :P
The good news is I did have 2 other stuff ups during the day so I'm no threat to winning the day anyways.
OK here are the results....
Click Here
Well done to all.
Stand outs for me are:
Daz - Good times all day without one mistake.
Ryan - Let someone else win RWD.
Chris Stacey - Great results for a first time.
Russell - Some great times
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
