Good work Daz :P
Next time I'll remember that bloody ABS switch.
Oh and I have to agree with Chris - Russell you are now a RWD gun. Some of your driving on the weekend was awesome. I look forwards to watching you and Ryan go head to head at Masters.
  • Replies 183
Posted Images
OK here are the results....
Click Here
Well done to all.
Stand outs for me are:
Daz - Good times all day without one mistake.
Ryan - Let someone else win RWD.
Chris Stacey - Great results for a first time.
Russell - Some great times
hmmm, people are catching up.
money cant buy talent, but it can by power apparently... so i think its time to invest.
Congrats Daz.
again, well done Russ;) and troy! Feck. 4thrwd... enthusiest for sure.
blahhh buying power is overrated :)
stock(ish) ftw! (or 21st in this case)
i agree, but i must admit i think some power would make things a bit more fun. sticky tyres and 140kw isnt very exciting under power. i want somewhat lairy power. similar to the green datto, slightly less than big red :) anything to make me laugh.
more power would be fun, if it was free...haha
is that what your cars putting out? mines in the same region but with crap tyres and stock suspension (besides sways)
bah
stock power, all 112kw of it (at the fly mind you) , street rubber,
only mods are springs and sway bars
20th!
all you need to do is avoid the cones and keep it straight
that being said I will be back in a diffrent car next time I do these, time for RWD turbo I do think
yeah, pretty much. for dutton we borrowed a Powerfc and got a whole 158kw out of it.. now it is back to standard comp with a little bit of boost... so im guessing 140.. maybe 150.
all you need is a set of coilovers to get a huge difference. im liking the semis on the front so i can stop and streets on the rear so it slides a bit more.
Just noticed a huge standout time! Mark in the 180b got the fastest second rwd run on th e mini wang of 25.95 in the 180b with 50kws and shit tyres. wtf thats fast?!
140kw and your still 1 sec faster than me on the long wang and about 2 sec faster on the skid pan (when I don't hit anything... which isn't often)... your not allowed to get more power!... in fact I think next time you should be forced to put the seats back in ... actually you should be forced to take out my seats and have them in your car as well lol
I'm coming with RE55s next time... might make up for my lack of skill... 'might' :)
wish I could have stayed for the battles, been watching the vids and they look like heaps of fun... best part of the day IMO
nice..thats some inspiration..although cbf with coilovers, i do have a set of semi's as well..might try them up front next time as well.
went even faster in the first run but got a penalty..
ludicrous speed..GO
Yeah I like that setup too especially on the skidpan. That's what I ran last time.
btw. If you buy power so will I :) I'm chasing you until I get a win. haha.
Nick. Did you find out what is wrong with your car?
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
