hey,i have a 32 gtst with an rb25, every time i slow down from boost i get white smoke that puffs out from the exhaust (fair bit)
none on idle or anything only slowing down. from what i know its probly a blown oil seal on the turbo... correct? if so whats a rough price for new seals with labour?
engine specs: standard rb25 turbo running 10 psi, 3 inch no cat, microtec, ebc, 040 fuely etc
also i have a brand new garrett t04 sitting around, would it be better to fit this? i have boch 040 fuel pump but standurd injectors, once again would like a rough price from ur experiance.
sorry to ramble on...
cheers dylan
https://www.sau.com.au/forums/topic/217573-turbo-problem-and-question/
Don't discount valve stem seals. You need to perform tests to determine which is the cause of your problem.
Remove the turbo and manifold and do a vacuum test on the exhaust ports to determine the condition of the valve stem seals. If they come up ok, then you need to examine the turbo.
I'm not about to go into depth into how you should do this as you won't even have the tools or equipment to test the valve stem seals anyway.
Good luck
sorry mate, it's a harsh reality. Valve stem seals are more likely to leak at negative cylinder pressure as the vacuum effect draws oil through the stem seals. They can weap at idle also but it slowly gets burnt away and not so noticable. On decel, the cylinder draws oil past the stem seal and because you have no real combustion until you resume accel, it will become quite noticeable at this point.
Could still be your turbo but would hate to see you replace it and have the same problem without checking it properly first.
3lit3 is correct, but decel will vacuum suck oil in from a few places, even up past the oil control rings in the bore [although rings usually also smoke after an idle period then accel].
I think you need to determine if the white smoke is oil or water/coolant as well, this could help you determine where to look.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
