I have been busy on the skyline today and I'm after some info on BOV's,
I know some skyline's idle best with a recirc and some seem to be ok with a traditional BOV?
I have lost the original location for the factory Recirc and I'm after a bov that stands a chance of idling ok,
this is why the factory bov is no longer an option :cheers:
any help would be cool before I buy one
cheers
Matt
Edited by buffy33
https://www.sau.com.au/forums/topic/217601-bovs/
biggest problem most of us have with the bov is that they can stall your car at low revs. that goes for manuels and autos. thou it is easy to start up again.
but as long as you are prepared for it then you shouldnt have a problem.
https://www.sau.com.au/forums/topic/217601-bovs/#findComment-3840997
Why is the factory bov no longer an option?
All you need to do is make a flange ,mount that to the intercoller pipe, bolt the stock bov back on and then fabricate up a plumback/recirc pipe that goes from the bov back to the stock intake pipe, you can make it from anything really, any a peice of hose the correct diameter will work fine to, i done this on my old r32 when i was using a R.I.P.S plenum and it worked perfect.
But if you want to have stalling issues, go ahead and buy a different bov :cheers:
Edited by nizmo_freek
https://www.sau.com.au/forums/topic/217601-bovs/#findComment-3841137
yeah i gotta admit when i had my stock ecu and was running a hks ssq bov i never had idle issues
now using after market ecu and a greddy type s and it still works fine.
but lookin at plumbin it back one day as im over the squeel it makes ha ha
https://www.sau.com.au/forums/topic/217601-bovs/#findComment-3841191
as above i run a stock ecu and a hks ssq and i don't have stalling issues either.. and i am going the route of the greddy plenumn and keeping the ssq. good luckl. if you want the factory bov then do as nizmo freak suggested. cheers hame.
https://www.sau.com.au/forums/topic/217601-bovs/#findComment-3841201
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
